Monster MotorsportChris Nott
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    HELP WITH THIS ...TAKE A LOOK.....PLEASE!!!!
    how can i tell if my maf is working as it should and if my car is running rich, 86.9 pence per litre 100 miles and 13.55 quid to refil. done a complete scan via -vag-com (no faults found)
    Also i want check if thermostat is working ok,as ive been told if it isn't car could still be on partial choke thus using more fuel,what temp should the choke cutt off?
    Also smells funny out the exhaust -smelly fumes?????????????????
    AUDI A4 TDI 130 AWX ENGINE. 2001>
    VAG-COM 607.
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    Unplug the MAF and drive around. If there is no difference in performance its knackered. If the performance becomes worse then it is less likely to be knackered.
    Your economy: 13.55/86.9p= 15.59litres/4.55= 3.42 gallons
    100 miles/ 3.42 gallons = 29.2mpg = you have a problem
    Thermostat sorry don't have a quick check for you
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Dec 2006
    hi, I thought that if you unplugged the maf and the performance remained the same this proves the maf is ok and not the other way around ? perhaps you could confirm this? (I have a 2.5 150hp and was expecting better acceleration than i have,I have run the car with the maf unplugged and on my car it made no difference at all) any help would be greatly appreciated.
    S6 avant
    Oct 2006
    bewdley Worcestershire
    689
    if the maf is knackered when you unplug it the car will run better. something to do with the ecu providing a stable fake signal close to that of a good working maf if it becomes disconected.
    ps, this doesnt work on tiptronic cars, they become quite undrivable without a maf connected. ive read a knackered maf can damage tiptronic gearboxes over time as the gearbox ecu uses maf readings.
    2000 s6 avant, special order met, green, satnav, Bose, tv, solar roof, privacy glass, recaro silver nappa.
