Sky InsuranceAH Fabrications
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    TDI NOT GTI! WHATS GOING ON?
    Filled up to the top,from shell (86.9 pece per litre) drove nice and nomal(no heavy right foot used) did 100.3 miles,went back to shell cost me 19.00 pounds! to fill up again!
    Whats going on,new temp sensor fitted fully serviced,it does take a few seconds to start,but only sometimes weather engine is hot or cold,will this make a difference? plenty of power in the car. Im sure it should of used no more than 10 pounds.
    HELP! A4 TDI 130BHP AWX ENGINE 2001 (B6)
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    temp sensor is new (4 week old) on vag-com temp reading was 80'C and on gauge was 90 ,is this a problem,if so whats the cause as sensor has been replaced?
    Also where is the thermostat located,is it a simple job?
    Aug 2006
    119
    im sure i have read that there is such a thing as winter diesel that is designed not to be effected by v.low temperature but deliverss less economy.
