AH FabricationsEM Tuning
Results 1 to 14 of 14
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Audi turning over but not starting.
    Anyone have any ideas what to look for. the glow plugs where replaced about a month ago. anything else to look for.
    Craig
    Audi A6 2.5 5Cyl tdi Quattro running 180ps 370Nm @0.9bar soon to be over 200ps
    AUDI URS4, URS6 and A4 1.8T breaking Lots of spares available at good prices. Large parts require collecting.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    has it run low on fuel? also check there is voltage at the glowplugs when you turn igniton on, fuse may have blown.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Immobiliser Craig?
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Car was running fine yesterday at about 12. went out tonight at 2000 and it never started. ??? there is plenty fuel in it. What voltage should be on the glow plugs. Where would i see fault codes?
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Usually with the immobiliser cars dont turn over but dont know about the Audis.....
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    I had immobiliser fault and had the same issues.the car would just start and no more then cut out.tell tale sign was dash lights flashing and fault with Air-Con on and off.igition key would not recoil back properly........ignition switch below barrel was broken
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Everything as it should be i think. Will check the voltage on the plugs and see how i get on. failing that garage it is as its too cold to be working on cars out side.
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Need the location of the Glow plug relay?
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I believe its behind the lower trim panel (above the pedals) there is also a large fuse there for the glowplugs. There should be 12 volts at the glowplugs.
    Chris
    See my images @
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Do i just measure the plug on each plug or do i have to take the plug out?
    New to Audi diesels ;(
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    the connection is common across all the plugs, just connect the positive of the avo meter to the top of the glow plug and the earth of the avo meter to the engine block or some other good earth. no need to remove the plug.
    Chris
    See my images @
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Cheers will give it a go.
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Check all 5 and all ok around 12volts. Started first time.???? Lots of smoke but it started no probs.
    The only thing that has changed is the weather is milder around 2degrees and lastnight it was -5degrees on the display. Or i have disturbed one of the plugs for the Glow plugs...
    Now what can i do to improve reliability?
    It is in need of a service but the glow plugs, fuel filter and oil changed 2000miles ago.
    Any pointers
    I see people on about the coolant temp sensor
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    I see people on about the coolant temp sensor. Should i replace it as its still not the best at starting......
