AH FabricationsVolks Autos
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,974
    a4 tdi PD Engine...how true is this??
    I was told by an independent audi/vw man that when engine oil cap is taken of a running pd diesel engine,smoke puffing out is normal,all pd engines do it!
    He showed me a 53 plate doing the same,he said this is normal for a pd engine. On an older (non-pd) engine its a bad sign,but not on a pd.
    Just wanted to know how true this was,maybe he's right 37 years in audi!
    Aug 2004
    Aberdeenshire
    740
    I've never taken the cap off a running engine but whenever I've checked the oil on a hot engine there was always a *little* bit of smoke when I removed the cap so I think it's nothing to worry about .
    Aug 2006
    119
    how come you were taking it off a running engine? just curiosity...
    Mar 2003
    UK
    426
    I believe you do it to check sump pressure - you are supposed to blip the throttle as well (a bit messy). I remeber by Dad saying something about it yonks ago. Now, I can't remember whether having oil forced out is good or bad...
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Evey engine will puff out smoke when the cap is removed if it is hot, the crank case is full of oil smoke and when you remove the cap is escapes. this is why there is an engine breather that leads into the intake manifold, it captures the fumes and combusts them in the cylinder.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
