Sky InsuranceVolks Autos
Thread: No blow
    Jan 2006
    UK
    19
    No blow
    Hey all,
    on a '97 A4 1.9Tdi:
    On two or three occasions I have noticed the following (really since the weather was hot):
    1) Following a motorway run, come off the motorway then accelerate away from the exit roundabout, car very underpowered. Feels like there is no boost.
    2) If I pull over, switch off igntion and restart immediately, normal performance is restored.
    Any ideas? I don't have VAG-COM. All electricals and hoses are in good order.
    Many thanks, Ben.
    Jun 2004
    Co.Tyrone
    hi,
    it could be your Manifold Air Preassure sensor at fault. I had the same problem with a golf and after numerous visits to the stealers ,new turbo and new maf sensor the fault was traced to the MAP sensor.It 's only a fifty quid part and hell of alot cheaper than a turbo.good luck
