    Mar 2005
    west midlands, england, uk
    14
    Noises When Turning Steering
    Hi all, I have suddenly developed a weird rumbling sound coming just behind the dashboard steering wheel (not the engine). its disappears when driving but as soon as i am idle I can hear it. This is not all, when stopped & engine on & I turn the steering wheel to the left or right, it has started to give a juddering rumbling sound. I have checked to see if there is enough PAS fluid & there is. Could it be PAS pump or something else ?
    I have an Audi A3 TDI 130 2002.
    Any advice would be appreciated.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Not sure about the first one i'm afraid, could be something loose behind the dash vibrating?
    The second issue sounds like a c.v joint problem, you shoule be able to check it quite easily, how many miles have you done?
    Mike
    Mar 2005
    14
    107,000 the noise behind the dash coincided with the noise coming from the wheels being turned.
    Aug 2004
    Hertfordshire UK
    162
    mine does this occasionally. i think the power steering system may need bleeding as its the pump being staved when the airlock reaches it.
    Formally a4 2.5 tdi (b5)
    Now Seat Ibiza tdi 130
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Quote Originally Posted by madmonzsta
    ok, if the noises are related that probably won't be the c.v joint
    As suggested above after 107000 miles it might also be worth changing the fluid used in the power steering system and see if that sorts the problem out.
    Mike
