Chris NottMonster Motorsport
    May 2006
    UK
    10
    v6 tdi versions 163 & 180
    newbie - I'm considering purchasing a 2.5tdi A4 either 163 or 180
    is there any mechanical difference between the 163bhp and the 180bhp engine (i.e larger turbo, injectors etc) or is it just the same engine with a different map
    it appears that the 163 can be remapped to almost the same output as the 180 which would suggest the mechanicals of the engine are the same ?
    imported_kris_tdi
    Re: v6 tdi versions 163 & 180
    the 163 is the same as the 150 bar mapping.
    the 180 has a huge list of different bits.
    ill see if i can find it.
    imported_kris_tdi
    Primary Differences:
    Heads
    Intake Valves
    Exhaust Valves
    Camshafts
    Roller-Rockers (150HP & 163HP has cam followers)
    Cam Belt and rollers
    Oil Cooler
    Mass-air Meter
    Injection Pump
    Injectors
    Vacuum Pump
    Turbocharger
    Intercoolers (Left and Right)
    Motor Mounts (Active)
    Fuel Lines
    Fuel Cooler
    Engine Computer
    May 2006
    UK
    10
    excellant - thanks for that
    in that case its probably worth going for the 180 then !
    T3RBO's Avatar
    Plymouth
    131
    Looking for a 2.5 diesel quattro so sorry to drag this post back up, but how can you tell the difference between the 150, 163 and 180 and the quattro from normal?
    Never bought an A6 before
    AUDI TT 225 COUPE|BRILLIANT BLACK|BLACK LEATHER|BOSE|TUNED BY VAGCHECK.COM
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by T3RBO
    AFAIK, all recent (not the latest A6) 2.5TDI Quattros are 180bhp. 150 and 163 are FWD only. However I'm not sure about the previous model A6/100
    Easiest way to tell is look at the sticker beside the spare wheel in the boot. It'll have the engine's KW rating which is approximately 0.73 of the BHP rating so 110KW = 150BHP, 120KW = 163BHP and 132KW = 180BHP. Quattro will have a propshaft under the car going to the rear wheels
