Results 1 to 10 of 10
    Mar 2006
    Cork, Ireland
    16
    How can I confirm if a 2003 1.9 TDI A6 Avant is 110 or 130bhp?
    Hi all,
    I am very close to buying an a6 avant in Ireland. It is a UK import.
    Could anyone tell me how I could confirm if the engine is truely a 130bhp?
    Either phsyically, or calling Audi UK or someone with the VIN/Reg ?
    Thanks in advance,
    James.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Re: How can I confirm if a 2003 1.9 TDI A6 Avant is 110 or 130bhp?
    James,
    If you can, check the spare wheel well, there should be a sticker in there detailing the KW produced by the car, if it's 96KW then its a 130bhp
    Failing that if it's a audi uk supplied car, they keep records of all the cars that they sell / service etc, might be worth a ring.
    Mike
    Aug 2005
    Scotland
    126
    May be wrong, but I think by 2003 all the A6s were 130.
    Mar 2006
    Cork, Ireland
    16
    Brill, thanks Mike and Mickey
    imported_hookie
    Failing that get the number off the ECU or read with a diagnostic tool or vag-com and I can check it that way.
    Mar 2006
    Cork, Ireland
    16
    Great, Thanks Hookie
    Mar 2006
    Cork, Ireland
    16
    Guys,
    someone told me that if the 03 avant avant se is 5 speed manual gearbox, then it is definately only 100/110bhp, and not 130bhp.....
    [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Is this true ?
    Thanks.
    imported_Macduff
    On the A4 the 130 bhp engine was available with a 5 speed box. IIRC that engine produced 210 lb-ft of torque. The 6 speed version produces 228 lb-ft.
    I would imagine that the A6 is the same
    Aug 2005
    Scotland
    126
    Correct - the 6sp manual has the higher torque (same as Multi)
    Mar 2006
    Cork, Ireland
    16
    Thanks again lads.
