AH FabricationsVolks Autos
Results 1 to 13 of 13
    Mar 2006
    Wiltshire
    \'95 80 Avant TDI running too cold/light flashing?...
    Can anyone help?! What is the usual running temperature for a '95 80 tdi avant? Mine seems to be in the 60 region, according to the temp gauge & the temp light is flashing, only after say 30 mins of driving though. What's going on?!
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    Re: \'95 80 Avant TDI running too cold/light flashing?...
    The running Temp should be Bang on 90
    When the light comes on that usual means that the coolant level is low or High Running Temp.......stupid question i know but have you checked the water level?
    Jan 2005
    Norfolk
    304
    or temp sender is reading incorrectly?
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    614
    As above, the coolant gauge should read bang on 90 degrees in normal running with correct coolant level as the thermostat on these engines is designed to open at about 87 degrees if memory serves me correctly.....
    I ran a '94 80 Avant TDi for a few years and when first acquired noticed that it wasn't going higher than about 70 degrees , even on the longest journey.
    Changed the thermostat and all was back to normal, with normal running temp of 90.......
    I'd recommend checking the coolant level, and if all is OK with no flashing light but with still cool running then change the thermostat. [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Mar 2006
    Wiltshire
    Thanks all... Yes, the first thing I did was check the coolant level - even as far as draining some out and adding more anti-freeze. So, I shall change the thermostat and see if that cures the problem. Let you know once it's done. Thanks!
    Mar 2006
    Wiltshire
    Also, is changing the thermo an easy job?!
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    614
    [ QUOTE ]
    [/ QUOTE ]
    Yes fairly easy.
    Remove under-engine tray and drain off coolant from the drain plug on the radiator (skip this step if you'd rather have a shower in anti-freeze when you remove the thermostat cover [img]/ubbthreads/images/graemlins/lol.gif[/img] ).
    The thermostat is hidden behind a black plastic 'elbow' held on by 2 bolts and with a large coolant pipe going to it on the n/s of the engine block, the thermostat is located in the base of the water pump.
    When replacing the thermostat it is wise to renew the 'o' ring seal that is present, although I remember that when I did this job on my own car ,despite having bought a Genuine thermostat and 'o'ring the 'o' ring was fractionally too large and I ended up having to use the old one [img]/ubbthreads/images/graemlins/frown.gif[/img].
    Luckily it didn't leak!
    Mar 2006
    Wiltshire
    Thanks... Shall see if this cures it!
    Mar 2006
    Wiltshire
    Right... Went to my local Audi specialist fo the thermostat and ended up coming away with a temp sender unit! He reccomended changing this first. He tried to explain where it is loacated in the engine bay... Can I find it?! Where is it?! Anyone?
    Mar 2006
    Wiltshire
    Found it but now i've dropped the clip in there, somewhere! Oh dear...
    Mar 2006
    Wiltshire
    Right, changed the temp sender and the thermostat. Now running at around 80 and light still flashes. Faulty header tank? Got one on order anyway. Also, the radiator fans don't seem to be working... Anyone know which relays are supposed to be intact? 1-3 are missing. Is this right?!
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    614
    Bit of a long-shot this, are you sure the switch in the base of the expansion tank that says fluid is low etc (think thats where it is!) is working OK?
    Can't see how a tank could be faulty- and I bet it isn't cheap knowing Audi stealers!
    I'd get the expansion tank switch off and make sure that it isn't the switch thats flagging up a 'phantom ' problem.....
    Oh, and in the 5 yrs/100K Miles that I ran my 80 Avant TDi for, don't think that I once heard the cooling fan(s) cutting in, they do seem to run cool ......
    Mar 2006
    Wiltshire
    Thanks... Changed to header tank - It had a slight fracture in it which may have affected the sensor when at full operating temp. The light has now stopped flashing and all seems to be well again. Relief!
