Chris NottJMB Retrofits
Like Tree1Likes
  • 1 Post By adamss24
Thread: 2.5tdi BAU drilled air box noise
    CHRISTOPHÉ's Avatar
    Mar 2014
    Plymouth, Devon
    70
    Hi all anybody drilled their air box and can show me what it sounds like? I don't want to do it and hate it but doing a full service at the weekend and it's in the back of my mind to do it!
    Allroad 2.5TDI 04 Manual on 19x9.5 BBS LM 402'd 30mm
    Uprated air suspension system, working on second air tank in spare wheel well.
    A8 4.2QS 98 on 20x10" sold
    May 2014
    St Helens Merseyside
    44
    Add al_p on Facebook Visit al_p's Youtube Channel
    bad idea don't do it , all you will be doing is sucking in hot air which is less dense than the cold air the box is getting at the moment , it will make no difference and if any at all it will make your economy and performance worse , the only mod that's worth doing is getting a free'er flowing air filter like pipercross (not k&n or oiled filters as the oil can get on the mass flow sensor causing inaccurate readings or in some cases braking the sensor) but even then free'er flowing filters are only really worth the money when you remap the car as then the engine demands more air
    Jul 2007
    London
    3,247
    No need to drill the box, the later 2001 onwards 180Bhp engines have a "cold air intake" at the bottom of the box so drilling is not necessary ! The feed is from the wheel arch area and i would keep it that way if you don't want your engine to hydrolock when going trough a deeper puddle of water !
    I run nearly 300 Bhp on a stock airbox, i would not even bother swapping the factory paper filter for the aftermarket jobbies...
    al_p likes this.
    FOR SALE:
  1. Wak box noise! And alternative with same air flow
    By Imola in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th September 2013, 12:23
  2. B6 tdi strange noise from air box on idle thumping sound....???
    By samsam in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th April 2013, 16:30
  3. Air box noise/chatter ?
    By Quattro180 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th January 2012, 17:54
  4. Drilled Air Box
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2010, 12:49
  5. drilled air box?
    By mastayoda in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2008, 12:03
