Sky InsuranceJMB Retrofits
    Sep 2011
    Reading
    Audi A4 1.9tdi tube at top of engine worn what is it?
    As title
    Thanks Ed
    kanecullen89's Avatar
    Jul 2009
    358
    Hard to tell at that angle. Is it a vacuum hose?
    Nov 2013
    Heath Hayes
    951
    Thats the vacuum supply for the anti shudder. When you stop the engine that actuator closes a butterfly flap in the EGR valve that stops air going into the engine. Because no air is going into the engine as it slows down it can't compress it so the engine slows a lot slower and more smoothly.
    Without the flap closing the engine stops a lot quicker and can rock the car a bit.
    Car will work perfectly well without it, a vacuum is only present for a few seconds when the engine stops. if you have the bonnet open and stop the engine you will see what it does.
    When I deleted the EGR on my car it had no valve and it didn't cause an issue.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Sep 2011
    Reading
    Quote Originally Posted by desertstorm View Post
    Karl.
    Ok thanks mate
  1. Audi A3 1.9TDI 2004 - Losing Power in 5th Gear and cutting out randomly
    By parin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th May 2010, 20:16
  2. Audi A6 1.9TDi Indicator & Rear wiper issues
    By chris2009 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th April 2010, 22:55
  3. Fitting Ignition barrel Audi A4 1.9TDI 130BHP
    By kashiskash in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th March 2009, 21:38
  4. Audi 80 1.9TDI Auto Estate For Sale
    By Michael Singleton in forum Classic Audi Forum
    Last Post: 16th July 2008, 11:52
  5. Audi A6 1.9tdi turbo runs ok when cold.
    By barney in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th July 2006, 17:00
