Badger5Monster Motorsport
Results 1 to 7 of 7
    Jan 2005
    Norfolk
    304
    sudden loss of power with 1.9 TDI engine
    This has happened twice to me today - going along at around 70mph and suddenly the turbo cuts out and the car goes in to limp mode. No warning lights appear on the dash and and all turbo hoses are connected ok. The engine is a TDI 110bhp (not PD).
    Any ideas please?!
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: sudden loss of power with 1.9 TDI engine
    Sounds like a sensor problem...............
    imported_kris_tdi
    stick it on vagcom
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    I've heard of this problem happening but usually a warning light appears on the dash.
    I'd agree with Kris - VAG.com will be your best bet
    Milton Keynes UK
    248
    I have had the same problem on my 1998 TDi 110. I believe it was down to a connection problem on the MAF sensor. Used contact cleaner on the plug and all ok for some time now.
    Regards,
    Jim.
    Jan 2005
    Norfolk
    304
    Had a diagnostic done today and it is almost ceratinly a faulty boost pressure solenoid valve (also known as an N75 valve?). The valve is becoming stuck open hence allowing a too much gas through which can over pressure the turbo hence the ECU shuts it down. I'm going to buy another although I have read that they can, perhaps, be cleaned......
    Sep 2009
    hi did u have any luck cleaning it or did u get a new 1.
    Mark
