EM TuningVolks Autos
    Feb 2014
    Question 1.9 tdi pd avf cranks but doen not fire up... Please help
    Hi guys, im new here so please excuse me if i am doing wrong.
    So i have a 2004 audi a4 avant 1.9 tdi 130 avf engine 133000miles.
    The problem is the car cranks over just fine as long as the battery dosent die, but it will just not fire, had the aa out, no codes on his scanner at all, he got the car started with some carb cleaner in the inlet hose. the problem is still there however, also when the carb cleaner ran out and the engine was running on diesel it started misfiring and running lumpy, when he accelerated and the revs came back down the engine cut out. AA diagnoses fuel pump on the crank shaft, however its only done 30000 miles. I checked the fuel lines today and the in tank pump is fine, priming as normal right the way through to the filter and out again no restrictions. I am about to check the fuel returns off the injectors. Also the cam belt was only done 1000 miles ago. Injectors and compression tests checked and passed.
    If any more info is required please let me know, I am really scratching my head now as i just cant figure it out.
    Please help as i need the car to get to work and back and at the moment im catching the bus which is horrible
    Sham
    Feb 2014
    Anyone?
  1. TDi 170 cranks but won't start
    By Steve220 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th February 2014, 10:50
  2. S3. Help car turns over but will not fire up
    By John ler in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2014, 16:54
  3. Replies: 9
    Last Post: 7th February 2012, 18:20
  4. Replies: 11
    Last Post: 1st March 2010, 17:27
  5. A3 2.0 TDI Superchip!!! Got it but not 100% happy.
    By danjones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2005, 20:07
