Badger5Sky Insurance
    Oct 2013
    no oil pressure 2.0 tdi
    hi all wonder if anyone has a idea i have a 2.0 a6 tdi in the workshop right now with no oil pressure i've changed the pump even though the origenle looked brand new checked the pickup and still no oil pressure also checked the shaft into the oil pump and it's like new i have hooked up a oil pressure gauge and nothing what so ever and the head is dry also have blown up the oil lines in the bottom end wile the pump was off and air was reaching the head
    Jan 2011
    northants
    165
    there as been so many mods on the oil pump/assy on this car
    check the oil pump hexagonal drive
    check the shaft is 100mm long not 65mm
    check the hexagonal drive in the balance shaft
    if its had the short hex drive it will have rounded out the hex in the balance shaft and even the oil pump
    also check the chain drive if its a 140bhp engine
  1. A6 2006 Avant BRE 2.0 Tdi intermittent orange oil pressure light
    By AUDIQS in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 16th September 2013, 12:26
  2. Audi A4 (B7) S-Line TDI - Oil Pressure Warning, No Power, Turbo? on M25...!!
    By SnakeOilDirect in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd December 2012, 02:35
  3. Where is oil pressure sensor on a 2.5 TDI
    By Turkster in forum Diesel forum
    Last Post: 6th July 2012, 19:12
  4. Help! Low Oil Pressure Warning on 2.5 v6 TDi
    By Peanutmnm in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2009, 00:52
  5. Oil Pressure Guage Problem
    By Crossbox in forum Classic Audi Forum
    Last Post: 23rd August 2004, 23:42
