EM TuningChris Nott
Results 1 to 1 of 1
    Apr 2013
    EGR Duty Cycle stuck on 99.6 %
    Hi,
    I have a 3.0TDi A6 (2010) CDY engine code and am getting pretty low MPG figures. I ran a VCDS log of Group 003 on my last trip to work and noticed that there constantly seems to be around a 200 mg/str difference between the actual and specified MAF values - actual being consistently higher. In addition, the EGR Duty Cycle does not change from 99.6%.
    No fault codes showing in VCDS.
    Any ideas on other tests I can perform? Thinking something not right with these readings.
    Thank you.
  1. 1999 S4 Boost pressure / injector duty cycle
    By marty.h in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2012, 20:44
  2. Modifying EGR duty cycle and fuel on TDi
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2008, 19:03
  3. N75 Duty Cycle.
    By jm-baker in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2007, 14:08
  4. EGR valve
    By Pookie in forum Diesel forum
    Last Post: 29th July 2003, 16:11
  5. window stuck unstuck
    By gregmmm in forum General Technical / How To
    Last Post: 9th June 2003, 18:05
