AH FabricationsChris Nott
    Dec 2013
    coolant temperature problem
    Hi folks,
    The coolant temperature dial on my clocks wasnt working (b5 a4 2.5 tdi) so i replaced the coolant temperature sensor.
    The dial is now moving a small amount, it still doesnt show the engine running at 90 degrees even after a 30 mile motorway run,
    Has anyone had the same thing happen to them ? If so what was the problem ?
    Cheers Andy
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    is the new CTS oem ?
    Sep 2013
    61
    thermostat fubar
  1. Water/coolant temperature problem
    By A3Bash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2011, 20:50
  2. coolant temperature sensor problem.
    By nu boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2008, 15:10
  3. G62 Coolant Temperature Sender - Replacement guide
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2007, 20:40
  4. Engine Coolant Sensor problem reveals oil in intercooler
    By alanmclean1974 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2006, 22:43
  5. trouble code coolant temperature below normal?
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2004, 05:36
