Sky InsuranceEM Tuning
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    72
    3.0 tdi .... Goes flat in 5th gear only ......
    The car :
    Audi A6 3.0 TDi Auto Quattro 2009 facelift
    CDYA engine code
    The problem :
    Hold a constant 2/3 's throttle - run through the gears without deviation - 1,2,3,4 all pull strong, smoothly drops into 5th and goes flat, still accelerates, then pulls strongly again in 6th
    The fuel econ is also poor, 25mpg to the tank (long range 80L tank) - mpg measure correctly from fill up to fill up.
    The parts it's had recently :
    Complete fuel system : hpfp, lpfp, regulator, injectors x6, rails x2, link pipes, vacuum pipes, filter, filter housing, relays, entire wiring and ECU check, tank swabbed out, front to rear fuel lines flushed out, software update, adaption values reset (fully adapted again now)
    Complete auto box rebuild - new oil, new transfer box oil, new rear diff oil
    Turbo inlet seal replaced
    Swirl flap updated and new rods fitted (both banks) (full adaption since this also)
    The car has no fault codes sorted, non pending
    All the work work has been carried out at main dealer Audi
    Anyone got any ideas ..... We are stumped .....
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Why has it needed all that work?
    Nov 2013
    Heath Hayes
    930
    How many miles has the car done ??. Seems strange that the car pulls fine in all gears except 5th yet they seemed to have decided that it may be a fuelling issue as they have replaced the entire fuel system by the looks of it.
    I would be doing some data logging on the road checking boost pressures, EGT temperatures, DPF differential pressures , Pump fuel pressures etc.
    Is it the gearbox that is limiting torque on the engine for some reason.
    Karl.
    Karl.
    NotNormal's Avatar
    Mar 2007
    Lincolnshire
    72
    Quote Originally Posted by Jamie-S View Post
    fuel system was down to swarf in the system, a component breaking down - it was a recall for certain engine codes and sizes
    swirl flap rods - common issue
    inlet o ring - relatively common issue again, you'd see an oily buildup around the pipe at the turbo end on the compressor housing
    Quote Originally Posted by desertstorm View Post
    Karl.
    Karl.
    They didn't attribute the fuel problem to this - the fuel system was replaced due to a component breaking down causing swarf giving a code of low fuel pressure P0087 - any when this happens it went into limp mode
    I was just clarifying what's been done ti try and be comprehensive
    my cars covered 103,000 miles
    DPF has been checked - both computer and physically - all ok
    thanks for your input so far, food for thought .... Will investigate further ....
  1. A3 2.0 TDI 140 BKD Juddering 5th/6th Gears under load
    By a3sportback54 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd October 2010, 11:13
  2. 5th gear reminder
    By jojo in forum General Chat
    Last Post: 2nd November 2005, 10:09
  3. 5TH gear on channel 5 - NOW!
    Last Post: 12th October 2005, 10:28
  4. Anyone watching 5th gear- parking scam
    By imported_Yaseen in forum General Chat
    Last Post: 22nd October 2004, 21:10
  5. engine goes flat at 3000 revs
    By ratty in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd May 2004, 02:21
