Sky InsuranceEM Tuning
    Sep 2013
    59
    dead MAF? AFB 2.5 tdi
    could I have a dead MAF
    car feels lack luster, was in my dads identical car at the weekend, much stronger than mine, no flat spots anywhere
    mine is especially flat 2500-3200/3500 then seems to pick up again
    i ran the log on VCDS this evening after spending the day changing the timing belts, wp, thermostat, all rollers, idles, tensioners, aux belts and tensioners, rollers
    timed the fuel pump with VCDS
    the log I ran was on measuring block 3, i have the excel file, and according to the manual at 3k rpm the reading should be 850-900mg/h
    im getting
    @3039 RPM
    MAF specified 792.9
    MAF Actual 451.4
    is the MAF toast?
    Jan 2011
    Aberdeenshire
    628
    Did it occur after the belt change?
    Did you lock the crank and cams when you changed the belt?
    VCDS will only time the pump.
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    Sep 2013
    59
    No was like this before, I did lock the cams, crank, injection pump them time with VCDS when warm..
    the injection pump timing was retarded before I started, between the middle and bottom line, now nicely between the middle and top lines
    Jul 2007
    London
    3,074
    Swap the maf with your dad's car, if it goes better then it's duff...
    FOR SALE:
    Sep 2013
    59
    not going to see him for a fortnight as hes off to scotland
    ive just picked a new bosch one up from Euro car parts
    much better, hopefully will equate to better fuel economy aswell!
    still not convinced its running 100% though
  1. MAF SENSOR ON TDI
    By clough103 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd January 2011, 23:36
  2. will an 09 airbox and MAF work/fit on a 54 plate tdi?
    By DOLPHIN DIESEL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2010, 17:08
  3. '99 2.5 AFB V6 TDi Timing problem!! Please help
    By owais2k in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th November 2009, 13:19
  4. 80 TDi "dead spot" on gear change
    By imported_JJlehto in forum Diesel forum
    Last Post: 11th August 2004, 11:52
  5. TDI MAF's Cheap.
    By t955daytona in forum Diesel forum
    Last Post: 6th October 2003, 22:23
