Sky InsuranceJMB Retrofits
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,157
    A4 2.5TDi Remapping
    Hi,
    Does anyone know any custom mappers that would be able to sort out a remap for me?
    The car is a 2003 A4 2.5TDi Quattro (AKE 180) engine.
    So far I have had two local companies load maps onto the car, the first one failed to make standard power (rolling road result was 178bhp at Dyno Dynamics), the second map was slightly different - may have even been the same map file?
    People have stated that 200bhp should be achievable - I just need to find a decent map / mapper to sort things out.
    Mechanically, the car is sound - top ends were rebuilt last year due to cam wear, fuel pump timing is spot on according to VCDS - no other error codes.
    All logs are consistent - boost, MAF readings.etc
    I know diesels tend to smoke once they have been remapped, but mine is clean and doesn't smoke.
    I'm guessing the file maps that have been used have not touched the fueling / smoke retard maps to keep the average customer happy.
    I bought a KWP2000+ and copied the current map from the car, I loaded the map into VAG EDCsuite - hit the virtual dyno button and supposedly its 168bhp max with torque slightly over standard - im not sure if this would be accurate or not, but kind of explains why its lacking somewhat.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    493
    Have you got an exhaust on it? And does your car have dpf?
    If it has a dpf that will be why it is not smoking, however if you remove this you will get amazing power gains and also a nice exhaust note - down side is it will smoke.
    There are various different place which offer generic or custom re maps, if you type it in on search box there is plenty to have a brwose through. All depends on what you are wanting (y)
    Hope this has sehd some light.
    Feb 2012
    Liverpool
    1,157
    Thanks Chris, sent you a PM.
    - Weitec GT
    coxy8329's Avatar
    Nov 2011
    Hampshire
    166
    You could try Rick at Unicorn. He's a site sponsor based in Stockport.
    He did the remapped my A3 2.0TDI, highly recommend him.
    Audi A3 Sline 170 2.0 TDI
    Mods Done
    RNS-E mkII fitted, Tinted Repeaters, Center Armrest,
    LED Interior Lights, Cruise Control, LED Number Plate Lights,
    VW fan windshield washers, S3 Pedals, Metal Footrest,
    DPF & EGR delete, Unicorn Remap, De-badged the tailgate.
    With DPF Without DPF
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Hi Alex,
    we can help you out. I'd want to do some diagnostics first with the standard map on to make sure it is running as it should.
    Thanks, Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
  1. Audi A4 B6, 2.5TDI Quattro V6, Remap.. Faulty??
    By quattro_izzy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th January 2010, 09:52
  2. want to remap 2.5tdi
    By steviequattro in forum Tuning
    Last Post: 21st September 2009, 10:42
  3. 2.5tdi quattro sport 180 - lumpy after remap
    By istoo in forum Diesel forum
    Last Post: 23rd September 2008, 19:36
  4. Remapping 1998 V6 2.5tdi Q
    By meatychi in forum Tuning
    Last Post: 22nd January 2007, 22:07
  5. A4 B6 2.5TDi Q Remap Help
    By G4JSG in forum Tuning
    Last Post: 11th November 2006, 09:37
