Volks AutosMonster Motorsport
    Jun 2012
    119
    1.9 Pre-PD TDI- Fuel Pump not working but posible fix?
    Hi all,
    Please can you try and help me. My girlfriend has an x reg 1.9 TDI Audi A3 and last week the glow plug light started flashing. We got the code:
    'Quantity adjuster upper limit reached P1562'
    Last Friday the car wouldn't start and no fuel was getting through to the injectors. My friend has just had time to take a look at the fuel injection pump and he said that "There is a stop solenoid furthest away from where the Cam belt runs (above the injector pipes) and the wire coming to the solenoid is not live with the ignition on.. I connected the battery to it and it did lift it"
    Please can I/we ask apart from replacing the pump, is there a repair he could do? Should the solenoid be live with the ignition on?
    Thank you in advance for any help you can give me.
    Jun 2012
    119
    Anyone please?
    Jul 2007
    London
    3,238
    Get a 2nd hand pmp mate, the pump you have is goosed. I had a few the solenoid arm breaks so it cannot advance the timing anymore hence the fault !
    FOR SALE:
    Jun 2012
    119
    Great, thanks for that.The part number is 029 00 355 32 B, can I ask does the next pump have to have the exact same number?
    Jun 2012
    119
    Thanks so much for that. My pump part number is 029 00 355 32 B, please can I ask does the next pump I get HAVE to have the exact same part number?
    Jun 2012
    119
    Problem solved....eventually! As predicted, a second hand fuel pump saved the day!
    Thank you to all of you for your help!!
  1. 2.0tdi fuel pump not making sucking noise
    By Ade6 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2013, 13:17
  2. 3.0 TDi - Fuel pump timing
    By Illusion-Paul in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th June 2012, 12:01
  3. 2.5 TDi fuel pump . . . . how much ? !!!!
    By Neil C in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th April 2009, 17:07
  4. Fuel gauge not working correctly A6 2.5TDI
    By K7ERG in forum Classic Audi Forum
    Last Post: 16th April 2007, 20:10
  5. HELP!!tdi A4, throttle not working,
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2005, 11:59
Tags for this Thread
