Volks AutosChris Nott
Like Tree1Likes
  • 1 Post By adamss24
Thread: Injector pump gone on 1.9TDI ASV 110hp? Do I have an internal pump in my fuel tank?
    Jun 2012
    119
    Hi all,
    My girlfrined's 1.9TDI (pre-pd) wouldn't start last friday after having the ESP light flashing for a few days. The AA man said that there was no fuel getting through.
    Just one question I would like to ask, my mechanic friend looked at the car today and said that there was no fuel in the fuel line between the fuel filter and the injector pump so he wanted me to find out if my car has a fuel pump in the tank that he thinks I should start with before going ahead and buying a replacement injector pump? (He hasn't got time to check it today you see).
    Please can I ask does my car have this?
    Personally, I think that being as the error code pointed towards the injector pump and the fact that the ESP light has been flashing kind of points towards the injector pump?
    Any thoughts on this?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,000
    I don't think there is one.
    Only one pump in the engine bay connected to the engine.....I think.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jun 2012
    119
    Wow this is confusing! My mechanic friend says that there are 3 fuel pumps on the car, one in the tank and TWO on the engine? Is this correct please?
    Jul 2007
    London
    3,235
    Get your car to another mechanic ! Your car has a vp37 pump which is run by the timing belt on the engine, if there's no fuel on the lines then i would bleed the fuel system first before condemning the pump ! Also a diagnostic scan will shed more light, the coil light will blink on the dash continuously if the simple electronics/mechanics fail inside the pump...
    ScottD3 likes this.
    FOR SALE:
    Jun 2012
    119
    Thank you so much for that. Last week, before the car broke down, the light was flshing on and off and the code showed 'Quantity adjuster upper limit reached P1562'. I believe this points towards the injector pump?
  1. Water pump gone?
    By rolphy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2010, 18:41
  2. 1.9tdi AWX engine - anyone know the air con pump part number ??
    By DodgeT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th May 2010, 20:58
  3. WATER PUMP faulty - overheating 1.9tdi PD
    By mystic.bertie in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th April 2009, 18:33
  4. Aargh Water Pump gone!!
    By steve_malton in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2008, 22:51
  5. A6 1.9TDi Vacumm pump gone! Ne one know where it is?
    By evomaster3000 in forum Diesel forum
    Last Post: 24th September 2005, 18:24
