JMB RetrofitsChris Nott
Results 1 to 8 of 8
    7
    Black Smoke - Help & Advice needed
    Hi All
    Really hope one of you are able to help
    This is the situation, black smoke coming out of the exhaust upon accelerating and moving off from a stationary position. The engine management light will appear after few day of it being reset by a family friend look at the car who is also a mechaninc.
    Work undertken so far:
    *MAF changed follwing the respective code being reportd on the computer the mechaninc has: P0101/000257 - Mass Air Flow Sensor (G70): Implausible Signal
    *EGR valve cleaned (not removed)
    *Turbo cleaned (not removed)
    *Diesel addative run through car in an attempt to clean up
    *Pressure test carried out - no leaks
    I am not sure the diagnostic computer he has but it cost him approx £2k it cover all modern car. He did a full diagnostic scan and picked up all the historic error codes.
    Once the engine managment light is cleared a few day later it reappears with the MAF error code. The MAF has been changed twice as the dealer agreed to swap out due to the same error code but to no avail.
    Initially I had a severe loss of power but following a MAF change and some additional software updated the power is back and turbo is behaving as expected.
    Fuel consumption is dropped drastically to approx 36mpg so really need to get this sorted as it has been going on for a few weeks now.
    Any help appreciated as to next steps, please let me know if you require any further information.
    Thanks in advance
    May 2012
    RETFORD, NOTTS
    1,753
    Any boost leaks? does it run better with AFM unplugged?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    7
    How can you check for boost leaks?
    Not tried it without the MAF....will do this tomorrow
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    is the maf oem or aftermarket ?
    7
    Bez i'll need to check but I think it was OEM
    Sep 2013
    16
    [QUOTE=sanj2000;2010215]How can you check for boost leaks
    check oul connection from turbo to intake manifold, (oul pipes tubes intercoler) often where is leak there is lot of dirt oil.
    black smoke is reason that engine is not enough air.
    7
    apologies for the delay, but wanted to run without the MAF for a few days. There is less smoke with the MAF taken off, and the overall running of the car appears to be smoother. MPG is still the same around 35-36 but guess this is due to the lack of MAF. One other thing I have noticed is that the car take longer to get to temperature and not blowing in hot air with the heating on appreciate that this may be due to the colder weather of late....but thought I would mention.
    Mar 2013
    Southampton
    128
    I have had similar issues with my TDI engine slow to get to temp, I would check the EGR is clean by removing it, and clean out the pipe work from the EGR back into the intake, as this was totally blocked solid on mine, once this pipework was clean the engine warmed up noticeably quicker. Though there is an underlying problem with mine as I have three knackered injectors which I believe is what is coking up the pipework. Your problem could be faulty/dirty injectors.
  1. help please, advice needed.
    By HOTTIGGER in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2012, 03:25
  2. HELP and Advice needed please
    By k10 in forum The Welcome Section
    Last Post: 15th January 2012, 10:30
  3. HELP AND ADVICE NEEDED
    By K50HYL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th July 2011, 12:31
  4. help and advice needed!!!!
    By s3chali in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2011, 19:54
  5. A4 1.8TQS Clutch Change......Help and Advice Needed!!!!
    By muz_amin in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd February 2010, 18:29
