Monster MotorsportChris Nott
    Jan 2006
    wales
    A4 1.9 TDI (90 BHP) - !997 power problem.
    Help would be appreciated. Initial problem was no turbo. Turbo and inlet manifold stripped,decoked etc.EGR valve changed.
    Turbo now working ( although not as impressive as before.)in lower speed range but no acceleration or speed increase beyond 70 m.p.h. I notice that turbo gate valve rod not moving despite high revs.
    MAF changed at onset of problem but of course made no difference.
    Any ideas please ???
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    Re: A4 1.9 TDI (90 BHP) - !997 power problem.
    I have read but not personally sorted out that there is a thin hose from the exhaust near the turbo to the ECU, and 90 / 110hp TDIs suffer from a power loss over 3000 rpm if this hose is knackered. If replacing this works please let me know because my wife is reporting similar symptoms on her P reg A4 90hp, but i haven't had time to fiddle yet.
    Jan 2006
    wales
    Many thanks for that - will check it out and let you know. Your wife's car is about the same vintage as mine.
    Best wishes.
