Originally Posted by
blackwagon
Hi,
My BV50 is also waiting to get installed.
I have to fabricate some adapters and also find a way to install the vacuum boost actuator that controls the vanes instead of the stepper motor that's on the BV50.
Adamss, have you already done some of this work to get the BV50 on ?
B.R
Stefan
Hi Stefan, i bought 2 exhaust flanges to weld on the exhaust and i am working at making adaptor plate for the turbo, biggest problem i see is adapting the oil return pipe to the old drain point in the block. At the moment i have a GT 2559v on the car (oil and water cooled, pretty much plug and play job) wich works fine just boosts a bit too slow. The BV50 i bought had no actuator (it was cheap for that reason) and i see no problem adapting a VNT20 vacuum actuator to work the vanes. I will have to grind the weld holding the vanes adjusting arm and weld a VNT 20 one as its easy to work with/fits better with the VNT20 actuator. I cannot see much difference between the GT2559 turbo and the BV50, the intake/exhaust wheels look allmost the same but the housing on the BV is much, much smaller...I think i should try and do a back to back comparisson between the 2 turbochargers... Anyone has a link to Bosio race nozzles for the v6 tdi AKE engine ? I think me Iveco nozzles are maxed out as i cannot get more fuel out of them !
FOR SALE:
