JMB RetrofitsEM Tuning
Results 1 to 9 of 9
    YSN
    YSN's Avatar
    Sep 2013
    93
    Is the Intake Manifold of the 1.9 Tdi 130 made of Aluminium??
    Hi everyone, I drive a B6 A4 Tdi brilliant car. However its on 113k right now and the EGR and Intake Manifold could do with a clean.
    I want to go down the Mr Muscle foam oven cleaner route but I know it eats aluminium. Just wanted to ask what material the EGR and Intake manifold is made of before I go ahead.
    Any help would be appreciated!
    Thanks guys,
    Yas
    Nr. Guildford
    133
    I'm no expert, but I would say they are some sort of aluminium/alloy. To be honest I cant see how a household cleaner would do much to it, its very thick material! When I did mine on my old Audi 80 I just scraped most of it out and used oven cleaner I think.
    2001 A3 Sport TDi 130 (ASZ)
    Milltek System & Downpipe
    'BlackSmoke' Remap
    Darkside EGR Blank
    CG Motorsport Dual Friction Clutch
    18" RS4 Replica's
    H&R Monotube Coilovers
    YSN
    YSN's Avatar
    Sep 2013
    93
    Thanks for the reply buddy, I tried the oven cleaner method it was ok but only for loose bits. IMO When I used the blow torch to burn it all off in the end I thought why did I even bother with the cleaner etc but there was a LOT of smoke lol. The oven cleaner is good for other things but for a gunked up intake manifold I must say blow torch FTW.
    Jul 2007
    London
    3,214
    I use the barbeque method, works every time...
    FOR SALE:
    YSN
    YSN's Avatar
    Sep 2013
    93
    lol what is the BBQ method?
    Jul 2007
    London
    3,214
    Barbecue ! You remove the inlet, soak in a bucket with diesel for a while then put on barbecue to burn the carbon deposits ! Don't go mad with the flame, i use a blow torch to initiate the burn then the flame will do the cleaning ! Power wash to remove all carbon and refit with a new gasket...That's all !
    FOR SALE:
    YSN
    YSN's Avatar
    Sep 2013
    93
    That's similar to what I did, but my one smoked up the whole place. I first tried to use "gunk degreaser" but that was taking too long and didnt actually work.
    Jan 2009
    Up tiddly up up
    71
    Some Avgas and some flexible wire brushes...
    took a while but boy did the crud come out!!
    YSN
    YSN's Avatar
    Sep 2013
    93
    I used a blow torch after I used it I was thinking I should have used that in the first place because its more quicker and effective.
  1. Replies: 2
    Last Post: 20th December 2012, 23:26
  2. PCV breather pipe under the inlet manifold part number anyone?
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2010, 10:48
  3. Getting sick of waiting for performance manifolds for the S3
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2010, 15:39
  4. Another performance exhaust manifold for the S3
    Last Post: 7th June 2010, 21:37
  5. Accessing the exhaust manifold area
    By golf in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2010, 19:02
