Sky InsuranceAH Fabrications
Results 1 to 1 of 1
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    412
    FUEL FILTER CHANGE 2.0TDI CR ENGINE 58 reg(2009)
    I'm wanting to change the fuel filter on my A3 but I wanting to know if any one with a CR(CBAB engine code) engine has done this and did they need to use the VCDS to prime the pumps before starting the engine as I have read that after a certain year of build spec just turning the key will not work.
    This is the same fuel filter housing I have
    Also which filter is required with this housing been looking on the car parts sites as there are a few to choose from and I think it the one without the blue inner 5 ring seal but the single narrow hole and flat bottom filter I need.I know the easy answer is to take the lid off and look but I would like get the right part first time and I know many of you out there have already done this job before.
    58reg 2.0tdi 140(WAS) S-line Monza Silver withSUPERCHIP BLUEFIN
    S3 front grill/gloss fog light surrounds/rnse/gloss gunmetal wheels/EZ front spliter
  1. 2.0 tdi diesel fuel filter change procedure
    By RGC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2010, 16:48
  2. Fuel filter change needed?
    By AndymacA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th April 2009, 18:26
  3. Fuel filter change
    By nik patel in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2007, 15:58
  4. Fuel Filter Change Interval 2.0Tdi
    By Gti Jazz Blue in forum Diesel forum
    Last Post: 25th September 2007, 11:06
  5. Fuel filter changing
    By A3-frankie in forum General Chat
    Last Post: 8th October 2006, 14:48
