Chris NottAH Fabrications
Results 1 to 1 of 1
    Aug 2013
    19
    2.5 TDi (AKE) Sticky Follower
    So, i'm a bit concerned...
    I've not had my cam covers off but a quick look down the oil filler cap of my 164k AKE suggests some cam wear and just recently, I've started getting a sticky follower on startup.
    The oil appeared to be in good condition (bought car a couple months back) but as soon as it started ticking, I stuck some 507 spec millers in. This cured the ticking for a while but now it's back....
    If it stopped ticking after a few seconds I wouldn't be too worried but at times it requires a small amount of driving to stop.
    With the weather starting to turn crap, is it likely to be ok 'til the spring or should I really be thinking about replacing everything?
    Cheers.
    2.5 TDi (AKE) Allroad
  1. Help! 2.5 tdi ake cam torque setting
    By stuartclarke in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2013, 16:44
  2. 2.5 tdi ake possible cams
    By ashleyretro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th March 2013, 18:36
  3. 2001 Allroad 2.5 TDI AKE engine code
    By danny_acs in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st November 2011, 08:31
  4. 2.5 TDIs AKE 180 BHP Quottros only....
    By Rossy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd September 2011, 07:52
  5. Cam fitting problem 2.5 v6 tdi ake
    By Yappy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th November 2010, 10:31
