Sky InsuranceEM Tuning
    Aug 2013
    HELP. Poor idle and engine judder.
    Hi, as the title states this is my problem. I own a 2.0 TDI A3 sept 2004 sportback. Just to clarify the work done so far, Audi have fitted a new cam belt, water pump and turbo. I have also fitted a new DMF/clutch, aux drive belt and tensioner and given the car a full service, all filters and all fluids. I have also just fitted a new EGR valve. Car is showing to codes and Audi can not find a problem. When the engine is cold the judder is small but once the engine is warm or If I put the car under some load the judder is worse. Is there anything I'm missing ?????? Any help or suggestions will be appreciated.
    Aug 2013
    same symptoms, changed turbo. check turbo with vcds graph
  1. Replies: 3
    Last Post: 13th February 2011, 19:40
  2. Help on non start and engine jult please every one.
    By Crazymoesizzle in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2010, 15:30
  3. 1.8t AEB poor idle problem and oil cap pressure
    By BBSparky in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th January 2010, 10:47
  4. Engine judder when idling
    By Nevdog02 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2007, 18:08
  5. Hunting idle and poor fuel consumption
    By gillbe in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2005, 13:59
