Volks AutosSky Insurance
Results 1 to 12 of 12
    Oct 2005
    uk
    23
    Unleaded in my oil burner!??? Oooops
    Yep I did it. I put Ł25 worth of unleaded in my diesel. But it doesnt end there....
    I was in such a panic I decided to start driving it ???
    100 yards later it cut out.
    Has anyone done this ? RAC say they cant just drain them anymore, they have to take it to a main dealer to be flushed.
    Any ideas how much this is gonna cost me?
    Its a '02 A6 1.9 TD Redi
    (i told rac the missus did it..... i know i shouldnt of)
    Tom
    mikeA2B's Avatar
    Aug 2004
    NW UK
    385
    Re: Unleaded in my oil burner!??? Oooops
    Very sad to hear Tom, I put diesel in my golf GTI once, its a horrible feeling.
    The worst thing you can do is run it after filling with petrol, if you didnt start your car all you would of needed to do is drain your fuel tank, but in your case the garage may need to clean your system and replace the filters.
    Diesel is less harsh than petrol so the pipes and sensors do not need to be as durable as the parts used on petrol engines, so any plastic pipes which may of been damaged by the petrol might also need to be changed.
    If your car is out of warranty I would suggest contacting a bosch or lucas diesel specialist, not the dealer as they are a lot dearer and wont be as familiar with cars filled up with the wrong fuel.
    Mike
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    The biggest problem is that diesel has lubricating abilities, and petrol has solvent properties and its possible that the petrol has cleaned away the lubricating diesel, therefore damaging the injector pump. PS This is worse case scenario, hopefully a few filters and a flush and you are in business again
    d3fy's Avatar
    Sep 2005
    Sheffield
    1,411
    Not to panic you mate, but I only saw a advert from the RAC last night saying what ever you do if you put petrol in your diesel do not drive it as it cost around 3,000 to put write????
    Anyone else seen that add?
    mikeA2B's Avatar
    Aug 2004
    NW UK
    385
    Yes saw it last night too, thats worse case I reckon.
    Apr 2004
    12,355
    see my post above, an injection pump etc can cost that stupid amount of money
    imported_CurryMilkShake
    In our co car fleet, this is a disturbingly regular occurence.
    Recent costs to resolve have included:
    Rover 25 2.0sdi - about Ł50, simple flush, refuel, no more problem
    Rover 45 2.0sdi about Ł180, flush, filters, flush again
    Audi A4 1.9tdi (Not mine!) about Ł250, not sure what they did, but returned it working
    Saab 2.0tdi - about Ł700!!! again, not sure what was done exactly, but several parts replaced
    all of these went to the appropriate main dealer for fixing
    Oct 2005
    uk
    23
    Thanks for your replies guys.....
    It got sent to Audi today, thansk to RAC.
    They say it will be Ł346 + Vat.
    They also have to fill it up with 'special' diesel so thats extra. Not as bad as I thought it would be anyway
    Ta
    Tom
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    [ QUOTE ]
    [/ QUOTE ]
    Is that like the "Special" washer fluid they put in which is more expensive than Optimax during an oil shortage?
    Milton Keynes UK
    248
    tfox,
    You should be able to find a garage that can solve your problem for about Ł90 not the amount you have been quoted.
    Putting petrol in your diesel tank is not too much of a problem unless your tank was empty. Before the petrol stations started to sell anti waxing diesel, people used to add about 5 - 10% petrol to stop the diesel waxing during sub zero conditions.
    Someone I know filled her diesel Focus up with petrol, she was having a blonde moment, the car drove although the engine knocked quite a bit. I ended up towing her to a garage and they charged Ł80 to drain the tank, put in about Ł5 of diesel and added injector cleaner. The car was fine after that.
    Oct 2005
    uk
    23
    moschino,
    Thanks for the info, unfortunatley Audi have doen the work now.
    I'll know next time (not that there will be a next time I hope)
    Tom
    mas
    Jul 2005
    n yorks
    128
    If you have a PD engine you are potentially looking at a new pump ŁŁŁŁ
