Chris NottVolks Autos
    Oct 2009
    25
    fuel filter housing
    Hi i have an audi a3 tdi 170 on a 2007 plate. I have just changed the fuel filter on it but it seems to be leaking from the lid.
    I have replaced the O ring and made sure to tighten the 5 torx screws one by one and opposite to each other thus maintaining even pressure. I have checked and cleaned both the surfaces on the canistor and the lid but it and made sure they are not deformed
    but still leaks. What am i doing incorrect or am i missing something? The new filter only came with an oring.
    Not a very good design in my oppinion.
    My other question is can i replace the whole housing for an earlier type which had top sealing ring on it(looks like olympic rings).
    Jay
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Did you prise the lid off with a screwdriver? You may have bent the top plate if you did, so use a pair of mole grips to clamp the top & bottom parts of the filter housing together which should seal things up again.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Oct 2009
    25
    I used a plastic trim removal tool. I think i have sorted it now. you have to refit the lid a certain way, ie there is a lip on the opposite side of where you prise to open, you have to hook it over then tighten the screws and not the conventional way of put the lid level then tighten the screws oppposite each other. hope that makes sense.
  1. Hesitation - Fuel Filter housing (170 tdi)
    By Smithymartyn in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th February 2012, 14:56
  2. Fuel filter housing
    By robby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2010, 22:18
  3. Fuel Filter
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2007, 12:08
  4. Fuel Filter
    By darrenp in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2004, 08:21
  5. S4 fuel filter
    By imported_BENS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th July 2004, 10:21
