Badger5Chris Nott
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Reesy
Thread: anybody recommend a good diesel injector cleaner?
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,755
    as per the title really,
    i have never added any of this to my tank and was wanting to clean things internally a bit!
    there are loads of diesel injector cleaners to buy out there, and one brand is always better than the next!
    just gathering opinions really of what you guys use/recommend and approve of!
    cheers.
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,901
    Re: anybody recommend a good diesel injector cleaner?
    Yellow fairy liquid is the best ....
    Can you not take them out and run them through a ultra sonic cleaner ?
    k03s/k04 hybrid a3 275bhp 293lbft
    vr6 mk2 golf gti
    fellow north east members add your name to this list.
    http://www.audi-sport.net/vb/north-e...%2A%2A%2A.html
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,755
    Quote Originally Posted by coatesy View Post
    nit wit!
    stop fishing!
    coatesy's Avatar
    Oct 2010
    1,901
    Quote Originally Posted by CHEZ View Post
    nit wit!
    stop fishing!
    Well you can look at it that way. But I clean my injectors by taking then out of the car and give them a few blasts in a ultrasonic cleaner. So you could do that ?
    vr6 mk2 golf gti
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,755
    derv injectors are not the same trench coat!
    first you have to take your cam cover off, unloosen a wiring harness, remove the injector which has a sort of spring mechanism on it that runs of a camshaft lobe, and then refit correctly which is a mega ballache, plus the fact that i dont think you can soak them in an ultrasonic bath like you can on a petrol injector.
    i basically want a good quality additive to add to my tank that cleans everything out.
    something that actually works.
    Reesy's Avatar
    East Sussex
    3,604
    Thought about running a few tanks of V power diesel at the same time Chez?
    Redex are pretty well known for this sort of thing, not sure if they actually do anything though.
    wesmaster likes this.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,755
    i used to use v power all the time mate until my local shell closed down!
    i seen the redex stuff but was wondering if thats any good or there is anything better just to wack through for peace of mind really
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Chez, if you take them out you can run through a cleaner but its not worth the ball ache for the amount of work you have to do to get to them.
    I would slap some redex through it.
    I've used it, several mates (same engine as yours) and my dad, all noticed results. If they was genuine or placebo effect we don't know.
    but worth a go.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    vag_fan's Avatar
    Mar 2013
    13
    Maybe try a few tanks of shells Vpower diesel
    Feb 2004
    Borders, Scotland
    405
    I use the Millers stuff, can't remember what it's caled now, used to be Powersport 4. Used it in my Golf TDI and now the A3, seems like a wee octane boost for the Diesel.
    Apr 2012
    Oxford
    126
    I had a very noticeable result from using BG244 (bought a couple of cans on Amazon) and will be running it yearly from now on to clear the crud out just prior to servicing.
    Sep 2012
    Milton Keynes, United Kingdom
    47
    All Redex is it's BP Ultimate..
    I'd recommend Wyns Injector Cleaner from my experience
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Liqui-Moly Diesel Purge is the daddy, although its not quite as simple as just chucking it in the tank SEE HERE
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Jul 2010
    Birmingham
    66
    I have just had the terraclean service done on my pd130 it has made car run alot better its and theres no more smoke on hard acelaration
    2002 Audi A3 1.9 TDi 130 SE
    Apr 2010
    15
    +1 bg244 great product used regular and just prior to a remap and they said the engine was running above stock bhp, not bad on a 100k 55 plate
    Sep 2012
    Bamfurlong Wigan
    199
    Add scr8pdo on Google+
    Paraffin and NO iam not $%cking about, I ran out of diesel the other day and had a gallon of Paraffin in the boot, in it went, ran fine, kicked out a bit of smoke on the boot then filled back up with diesel when I got to garage, 2 weeks later the car is running much sweeter and hardly ANY smoke no matter how hard its pushed (dunno bout legalities) but injector cleaner is full of Kerosene anyways IT WORKS
  1. 3.0TDi Injector cleaning? STP Diesel Injector Cleaner?
    By Illusion-Paul in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th July 2013, 09:31
  2. Can anybody recommend a good car cover?
    By MTRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2013, 21:17
  3. Recommendations on a good diesel fuel cleaner
    By amit91987 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2012, 21:59
  4. Need Recommendations For A Good Diesel Doing High Miles
    By emzino in forum General Automotive Chat
    Last Post: 6th March 2010, 17:50
  5. Anybody recommend a good home air-con machine??
    By bravepilot in forum General Chat
    Last Post: 29th June 2005, 19:58
