Volks AutosAH Fabrications
Thread: tdi problems
    Oct 2005
    uk
    tdi problems
    Hi i have had a problem with my tdi audi 80 for over a year now . It kicks like mule intermitently , all the fuel lines have been swapped so not air getting in . injectors cleaned all ok and the air filter changed anybody got a clue please help. [img]/ubbthreads/images/graemlins/cry.gif[/img]
    tubtub's Avatar
    Jul 2005
    SW England
    160
    Re: tdi problems
    It's often the MAF sensor (see other thread).
    Oct 2005
    uk
    Re: tdi problems
    Hi just in case anyone has a similar problem it wasnt the airflow meter?
    When i had taken the pipes off everything inc the inlet manifold was really crudded up a pain to get off but once cleaned is 100% better.
    imported_5u8z3r0
    Re: tdi problems
    Sounds like injection pump. Would need to really see and experience the fault to be 100%, but the way you have descibed it, and my experience leads me to suspect the pump.
    Jan 2005
    Northern Ireland
    10
    Re: tdi problems
    Is it running too rich? Should clean itself if you give it a good blast every now and again.
    Are you running a remap/ chip/ tuning box?
    JD
