EM TuningJMB Retrofits
    davidfox280585's Avatar
    Aug 2009
    108
    very very strange issue
    hi i have bought a 2001 51 1.9tdi pd passat 101hp model
    symptoms are,
    will not start from cold or hot, but if you drain the complete diesel system it will run off the key perfect,
    then drive it 200 yds, come back,
    turn it off and just spins and spins trying to fire
    if you bump start it it will run perfect till you turn it off even though it will not fire off the starter
    spinning over at 260rpm on cranking
    parts we have replaced,
    cam,crank sensor
    redone the fuel lines in the bay,
    checked for fuel leakage at the rear
    checked the intank pump is working while cranking
    coolant temp sensor
    new battery
    new fuel filter
    checked the injector loom for damage
    code read ecu shows nothing
    cleaned egr and checked its shut
    checked engine timing and fitted new belt kit
    we have had it to the local surestart diesel specialists who do not know whats wrong,
    i am not sure they have checked injector rate at cranking
    any ideas what to try next?
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    748
    Have you checked the injector pump timing?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
  1. Very odd brakeing issue
    By drfeelgood in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2011, 16:38
  2. Very Very tempted
    By garratt83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2007, 09:48
  3. Replies: 8
    Last Post: 7th February 2007, 18:38
  4. Very Very cheap cars on ebay
    By dgannon69 in forum General Chat
    Last Post: 25th September 2006, 06:30
  5. Very Very Wierd????
    By Alonzo in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2004, 13:18
