Badger5Chris Nott
    Feb 2013
    Please help me identify my engine and turbo o/p about to "Mr Muscle" it!
    Hi,
    So this is related to another thread, but what version engine layout is my 1996 Audi A4 TDi (1.9).
    What I'm look for is where the output of the turbo goes: i.e. I can see where the exhaust drive is going (the larger pipe under that labelled 'E') and where the air intake is (labelled 'A'), but where is the blown output going?
    I'm about to "Mr Muscle" it, but can't immediately locate the turbo output (I presume its underneath all this)....
    Anyone know of a good on-line schematic?
    Steve
    Jan 2011
    northants
    165
    remove pipe E
    with a small hose direct mr muscle into the turbo towards the inner wing side this will go to the veins
    leave to soak and then operate the lever from the vacuum diaphram below turbo at centre until it moves fully stop to stop and free
    Feb 2013
    Quote Originally Posted by towcestervag View Post
    remove pipe E
    Many thanks, only just seen the reply!
    Will try over the bank holiday.
    Oct 2012
    26
    don't listen to that last post!! your engine is an AHU . It doesn't have a variable vein turbo! its a wastegate type and does not need the mr muscle treatment!
  1. Please help me i need a new turbo :(
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2010, 11:47
  2. Please Help... Problem after service - Engine Warnign Light
    By bl_1969 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2008, 17:45
  3. Engine is fixed... follow on from engine and turbo is dead
    By PhilR in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th March 2007, 23:10
  4. Anybody please help me identify this?
    By Nessy in forum Classic Audi Forum
    Last Post: 3rd January 2007, 20:44
  5. New engine and turbo is now what I need!!!
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2006, 17:29
