AH FabricationsSky Insurance
    Feb 2011
    15
    2.5 TDi A6 stutter/ shudder/ splutter between 1200-2000
    In the last few days my A6 2.5 TDi car has developed a stutter/hesitate under acceleration and high speed cruising almost like having a large flat spot that lasts around 1/2 a second, every 2 or 3 seconds.
    Most noticeably, this happens on the motorway under normal driving whereby at 1500 -2000 rpm the engine power dips then returns quickly, this was constant on my 1 hour drive home just now. There are no engine warning lights on the dash but it felt like a mis-fire.
    The problem seems to happen throughout the rev range, there is quick dip in power and in the rpm then it will gather some power to accelerate then happen again and again. If I pull away from a round about slowly the problem isnt too bad but if I were to gun it, the engine would cough and splutter untill I backed off the power.
    Last night driving home up the M11 she struggled past 50mph, first morning she is fine albeit when I stick my foot down for hard acceleration.
    I have done some research but can't find much regarding this same issue, has anyone got any experience with this?
    Any thoughts would be helpful
    DC
    Jul 2007
    London
    3,079
    What year is that ? Any fault codes ?
    FOR SALE:
  1. 2.0 tdi hesitation/stutter between 1400-2000rpm
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2013, 11:22
  2. 2.0 TDI Random Stutter
    By Bing_IRL in forum Diesel forum
    Last Post: 11th July 2013, 10:31
  3. tdi bkd anti shudder valve
    By bigal23 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th October 2012, 01:09
  4. a3 2.0 tdi 2004 8p shudder on idle when warm, timing???
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2011, 23:12
  5. Update on my stutter/judder/vibration between 1200rpm - 1800rpm
    By sarah1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th June 2010, 16:29
