AH FabricationsSky Insurance
    Mar 2011
    Noisey Engine?! - 2.0 TDi 2005 55 plate
    Hi Guys,
    Previously had a 2006 A3 2.0 TDi last year winter I was impressed with, had that remapped and it was quick and fairly quiet, so much so I decided to buy another one this year for a winter hack. I bought a 2005 55 facelift - the engine I find very noisey on this particular one, it pulls very well and produces better MPG than the last one, once warm its much better.
    From cold its very noisey and sounds like a tank. - Its on 99k has FSH and always had the oil done fairly frequently. Is there anything that could cause the extra noisey-ness? I'm going to change the oil and filter again using Castrol 5-30W EDGE FST - is this the best to use or something thicker like 5-40 EDGE FST?
    Cheers for any assistance
    May 2011
    195
    Look in the A4 B7 section under oil pump/balance shaft failure buddy
    Mar 2011
    Quote Originally Posted by fossie View Post
    Thanks for the heads up matey, mine had some work done around 70k at audi funnily enough will have a look, I know it had a bottom end rebuild + new clutch + Fly + synchro and bits hopefully that has been done
    I think some 5w40 PD oil is better for this engine, 5w30 is a little thin, they always used to pop 5w40 in them and the engine hasnt advanced at all on a 55 plate
  1. Audi A3 2.0 TDi ( 53 Plate ) Engine Trouble!
    By senser_pro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2012, 15:03
  2. Different Speed ... same engine 2.0 tdi dsg
    By n3cr0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2007, 00:34
  3. Replies: 12
    Last Post: 14th November 2006, 13:42
  4. Loud Rattle from engine - Audi80 '93 TDi
    By LongI in forum Diesel forum
    Last Post: 11th August 2006, 19:43
  5. Avant TDI M plate lumpy at constant speeds
    By garymc999 in forum Classic Audi Forum
    Last Post: 24th January 2006, 19:14
