Volks AutosJMB Retrofits
    Jun 2012
    12
    A3 2.0 tdi - Radiator outlet sensor
    Engine managment light came on a few days ago i ran vcds and it came up with the error " coolant temp sensor radiator outlet g83 or 63" i changed the coolant temp sensor at the back of the engine 2 months back and need help finding this one now and any part numbers if anyone knows,thanks
    Boon's Avatar
    Sep 2012
    South East Kent
    411
    Mine has the same, also changed the sensor between the block & battery. No fix!
    Seems to be a common VAG sensor go... My mates S3 8L and another's VW Lupo both had the same sensor fault on VCDS
    All 3 run fine and dash temperature gauges work fine so not bothered me much!
  1. Radiator temperature sensor and thermostat part number request
    By delgadoalonso in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2011, 21:14
  2. A4 (B7) 3.0 TDI Fuel Pressure Sensor
    By sc00byd00byd00 in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th April 2011, 15:00
  3. 17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
    By casiodan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th February 2011, 21:25
  4. 2005 2.0 TDI engine temp sensor or glow plugs.
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 31st August 2010, 21:32
  5. 2008 A4 2.0 TDi radiator to fit 2006 A6 2.0 TDi??
    By chodecz in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th June 2009, 19:36
