EM TuningMonster Motorsport
    Jan 2012
    Please help with 2,5 V6 tdi Allroad Tiptronic problem!
    Hello Adammss24 has despaired by my car if a big problem with the torque has what, unfortunately, no more alls 456NM would like to bring me. Have in my car pair of tuning measured took, tuning nozzles BUILD with Firad 50% more flow on diesels, big loading air cooler, and 180 HP of turbocharger. My car is a series 150 HP of engine is AKN with 5way TipTronic Allrad. The problem passes in it I the torque no more as a 456NM can begin, the feeling has firmly anchored in the gear control device stands. At the moment it is thus I as soon as I with 2000 rpm in 5 ways full power does the torque on 456NM, however, does not rise more in the VagCom is indicated and the converter bridging structure starts to Schleifen:-(treasures At the moment I with 500NM lies with the power. Now my please to you is, am on that looks for a solution to this problem. Has already looked in the net who is to be fitted in the case my gears software thus in the bridging structure-converter to more Pressure of the lamellae on the lamellae gives or maybe the hydraulic pump more print delivers, something what the problem solve acts.? Hope you can help me there with would please me gigantically!!!
    Will send sometimes the software of my gear with and an already modefiziertes file and a log of a few measuring value blocks from gear! Are block 07-09-10 with VagCom!
    Thank me with all can help me and idee for me have or Softly so can furnish. Should also not be of course around, otherwise.
    If somebody hopes mine can solve problem!
    Thousand thanks!
    File-Upload.net - VW_Passat_D25_V6V4T_110kW_0260002785_8D0927156DQ_8 99988_AG5-1V.rar
    Jul 2007
    London
    3,252
    Sorry mate, stop using the translator and get someone fluent in english to ask the questions ! Cant make sense of what's said in the post...
    FOR SALE:
  1. Help with oil ? 2.0 TDI
    By Adam-f in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th May 2011, 10:16
  2. Replies: 3
    Last Post: 13th February 2011, 19:40
  3. Please help with aftermarket stereo 1.8t cabriolet
    By mickmk4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2011, 21:47
  4. Just put deposit on this Orange S3 - please help with engine details?
    By jamieswales in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2010, 16:53
  5. Please help with codes..airbag.
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th July 2008, 02:01
