EM TuningAH Fabrications
    Jun 2007
    Norfolk
    66
    Requested MAF and Actual MAF values
    I have an issue with my car - A4 3.0TDI
    It all started when i didn't think i was getting good enough fuel economy
    I have replaced the airfilter to a K&N
    I have cleaned the EGR, and actually disconnected the pipe so it remains closed now.
    Cleaned the first plastic inlet manifold
    I have done a few VAG logs and the issue is this:
    Requested Boost and Actual Boost are about the same
    The MAF requested takes a step change when foot is fully depressed on the throttle,
    However the Actual MAF values take a very long time to get there, but never reach the requested value
    At 3000 rpm, it is almost at the requested, however then it levels off below the requested value.
    Can someone give me any idea what could be wrong?
    Will post the graph up tomorrow
    Jun 2007
    Norfolk
    66
  1. Cleaning MAF and Throttle Body
    By dot32 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2013, 19:48
  2. MAF and CTS
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2008, 11:33
  3. RS4 B5 and B7 MAF's
    By Jay D in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 29th November 2007, 13:43
  4. Just changed MAF and now things are worse!
    By spencerjoel in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2007, 10:52
  5. Best type of MAF and UK suppliers?
    By cluelessgoon in forum Diesel forum
    Last Post: 18th December 2006, 00:58
