Monster MotorsportChris Nott
    May 2012
    A4 2001 V6 TDi Cam Lobe wear
    Hey guys
    I'm looking at a V6 which is the timing is out on due to the common cam lobe wear issue. Before I part with my hard earned cash - how bad can this problem potentially be?
    Is it a case of swapping out the cams for new ones, or can it potentially be a lot worse?
    Any idea of cam costs?
    I'd really appreciate the heads up, and what to look for in this car to assess the cam problem before buying!
    Jul 2007
    London
    3,234
    Camshaft kit is £600 to 800 of ebay, stay away from cheap ones. Get a full cambelt kit and thermostat fitted at the same time for good measure.
    I have fitted Kolbensmidt KS cams and forged rocker arms + genuine INA lifters, bought the kit for £700 before X-mas. No issues and car is running as sweet as the day one !
    I bought my camshaft kit from this seller, good price and quick delivery...Make sure to email him for the right parts...
    CAMSHAFTS & GASKETS FOR 2.5 TDI NEW TYPE BCZ BDG BAU BDH VW AUDI SKODA A4 A6 A8 | eBay
    FOR SALE:
    May 2012
    Thanks for the swift reply - is there usually anything else that may need replacing. I've done the usual googling, and I'm sure I read somewhere that somebody needed the heads rebuilt?
    Jul 2007
    London
    3,234
    Heads don't usually need rebuild just as a result of camshaft wear, if it drops a valve then it's a different matter. What model, year and spec is the one you interested in ? I know of a nice a6 tdi quattro sport i sold to a friend of mine with a brand new engine (new heads/cams/valves/cambelts/rollers,etc.), he bought a 04 reg allroad hence the sale...
    FOR SALE:
  1. 2006 A3 2.0 TDI Quattro Sportback rear tyre wear
    By ADAMD40 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2011, 23:12
  2. Camshaft wear A4 b5 2.5 TDI AFB '99
    By [BoR] in forum Diesel forum
    Last Post: 18th October 2011, 22:29
  3. 2.0 TFSI HPFP Cam Lobe and Cam Follower
    By KRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2008, 05:46
  4. TDI 170 Tyre Wear!!!
    By coupe-se in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2007, 21:30
  5. 02 Audi A4 TDi 130 - brake wear
    By sinbadfury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2005, 23:04
