Sky InsuranceEM Tuning
    Mar 2012
    21
    A4 tdi engine problem
    Just had my head gasket done and noticed I have a cracked piston. Been advised to replace the full engine. My engine is 1.9tdi pd engine 115ps. Engine code is brb bke. Does my replacement have to be exactly the same? Or could I buy the bottom half of another engine and use my head? If so, will it have to be the same engine code again as the avf awx engines seem the same?
    Mar 2012
    21
    The car is a 2006 s line avant
    Jul 2007
    London
    3,081
    Why don't buy a set of pistons and have a machine shop lightly hone the block ? It might cost the same as a 2nd hand engine but at least you know your engine and not take a gamble with an unknown lump.
    What was the reason of the piston to crack ? Do you run a remap ?
    FOR SALE:
    Mar 2012
    21
    Yeh it's re mapped. Still unsure as to why the piston cracked. I've just had a new engine fitted, but it's seems like its over fueling now, miss firing now aswel! I'm baffled!
  1. A3 tdi 2.0 8p (engine cooling fan managment system) PROBLEM!
    By slick-A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2012, 20:35
  2. A3 2.0 TDI ENGINE WHEN SWAPING DOES IT HAVE TO BE SAME ENGINE CODE
    By westu_123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th August 2010, 18:51
  3. A6 1.9 TDI engine management problem?
    By oxford_hippo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th March 2010, 09:58
  4. A4 Tdi, engine problem AND steering problem! PLEASE help!!
    By mattsavage in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2007, 16:02
  5. 2000/2001 A3 TDI (ENGINE PROBLEM)!!!
    By mr964porsche in forum Diesel forum
    Last Post: 26th June 2006, 23:32
