Sky InsuranceChris Nott
    Jan 2012
    Help with Transmission Control Module V6 TDI Tiptronic
    Hello to all the user has a problem with my Tiptronic auto gearbox, a 2.5 V6 TDI 150ps AKN. find someone to help me. problem is that I take the nozzle fitted with Bosio Race 683 and now have the TipTronic .Es now someone should raise the hydraulic pump in the transmission of Sun software to 30% more contact pressure of the blades, because the time they slip through the gas type :-(!
    Hope someone can take to help with my problem and I!
    Transmission is a ZF gearbox software 8D0927156DQ FNM or has anyone of you this software for?
    Thanks a million!
    Jan 2012
    Good morning to you! None of you has a hint how or who can help me?
    I really need your help and I hope it can be to know someone to provide, thank you!
  1. Tiptronic Transmission Woes
    By g.suggy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th December 2011, 15:04
  2. control module fault
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2011, 23:58
  3. Replies: 0
    Last Post: 30th December 2010, 12:50
  4. Unable to log into Engine Control Module to activate Cruise Control
    By jsh712p in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th June 2010, 09:47
