VAG CheckDTUK
Results 1 to 8 of 8
    HIGGINS's Avatar
    Mar 2010
    507
    Post Thanks / Like
    De-cat bad for the turbo?
    Basically ill try and cut the story down.
    I have a custom straight through cat back and i went to my local exhaust place to get them to remove the cat. They basically said they can do it but it could destroy my turbo within half a year as it will be spooling up too quick.
    Is this true? :S
    Im sure theres ALOT of people with straight through pipes
    Selling MY11 rear lights, message me for a price
    sportstractor's Avatar
    Gangsta
    North Devon
    2,404
    Post Thanks / Like
    Not true, that's why turbos have a internal waste gate. Just sounds like somebody trying to be a know it all
    S3 - Minger AMK - Stage 2 Custom 'R-Tech Powar' Remap - Badger 5 Tip - Welly Cooler - 25mm eibach springs - S4 reps
    "Remember one thing, No matter how pretty she is, Someone, Somewhere is sick of HER SH*T!"
    HIGGINS's Avatar
    Mar 2010
    507
    Post Thanks / Like
    I mean i didnt believe it really my self but i thought it must be true as they are an established exhaust centre :S
    So should i just get it done? :P
    Gangsta
    North Devon
    2,404
    Post Thanks / Like
    What car is it? You don't get cats on diesels?
    Gangsta
    North Devon
    2,404
    Post Thanks / Like
    Oh iv just been informed you do get cats, but they are different to petrol cats.
    I personally wouldn't remove it, unless you massively modding it ( ie bigger nozzles, custom map)
    Oct 2003
    up north...
    767
    Post Thanks / Like
    Audi diesels have a cat, and you can remove it and still pass an mot. Removing it will improve flow, increase turbo spool and reduce turbo temps- particularly worth it if you use a hybrid turbo that usually spool slower cos of the heavier compressor wheel
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    George 1982's Avatar
    Jan 2012
    Newport, South Wales
    16
    Post Thanks / Like
    I've just bought a decat for my 130 pd before I go in for a remap.....hope this line about killing turbos is wrong !
    Jul 2007
    London
    1,574
    Post Thanks / Like
    Some small turbo's are known to surge and by removing the cat you experience "boost creep" which means the turbo overboosts even with the vanes fully closed ! Surging is very bad for turbo/engine as it can lift heads and snap the shaft which almost every time could lead to hydrolock !
    If you have a KP39 or Garett GT1749 Va i suggest you leave the cat in place ! I would remove the cat if you have a bigger, slower spooling turbo...
    FOR SALE:
  1. boost leak pressure test bad for turbo ????
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2010, 13:34
  2. Turbo Downpipe to CAT
    By Mart in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th December 2008, 01:22
  3. Cat and turbo... Oh boy!
    By AudiSport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th April 2008, 08:47
  4. Glowing Turbo. Bad news ?
    By s3bow in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2005, 23:47
  5. Help getting my bad turbo rebuilt?
    By mike85 in forum Classic Audi Forum
    Last Post: 5th May 2004, 01:11
