VAG CheckAMD Technik
    Sep 2011
    Post Thanks / Like
    Unhappy v6 tdi warm start problems
    Morning, i have a 2001/2 2.5 tdi AYM engined audi a6, i ve not had the car for long about 6 weeks, occasionaly when warm it was difficult to start but once started it ran fine, it starts from cold no problem, i have just had all the belts and water pump changed and all seemed good for a week or so but now it is really really difficult to start when warm, if ive left it stand for and hour or more and then try to start it it cranks for ages with white smoke out of the exhaust once started, if i start it a few mins after i turned it off it will start no probs, it just seems once ive left it maybe an hour or more, the fault code it came up with was the coolant temp sensor which i have changed and now the temp gauge works too, although the temp never seems to get above 70/75, i thought they normally ran about 90? it cranks over plenty fast enough i would say and the battery seems fine too.
    any help would be great as this is doing my head in and im on rather a tight budget at the mo so hope its not costly, right over to you guys and gals
    Thanks Rich
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    955
    Post Thanks / Like
    did you change the thermostat also when you did the cambelts. this is the usual reason that they never reach 90.The thermostat is next to the water pump and a belts off job to change. Have you also checked the fuel pump timing on vagcom just to see if its operating at the correct timing. Should be set up once the belts are changed.Worth eliminating first before starting to look for problems with other stuff
  1. a4 tdi poor warm start
    By matty-a4 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 27th October 2010, 15:09
  2. 2005 2.5 TDI All Road Start Problems - HELP!!!!
    By LanciaNut69 in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 26th January 2010, 07:39
  3. Fuel Economy and warm start.
    By sharpy in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2009, 08:46
  4. 1.8t avant warm start problems help!
    By Mark L in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th July 2008, 10:21
  5. 1.9 tdi (1997) warm start problem
    By markf497 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2006, 17:20
