New Battery wont hold charge
twist123
NULL
Hi All,
A4 B6 130 wouldnt start a week ago, checked battery and it was the original Audi part, so thought its time to change.
Bought a new Bosch S4 fitted and all was fine when I drove it daily, parked it Friday and left it till this morning (Monday) and when I started it the low battery (brake symbol) came up and it sounded sluggish when starting.
Hoping someone can recommend me a few things to check, so far I need to:
Check the black box on the positive terminal
Check alternator cables arent corroded
Check if Hazard light stays on
Check battery voltages when running and not running
Can you guys think of other checks I need to do?
Thanks in advance
have batt and alt checked
could be the alt not putting enough charge in
check brake lights aint turning on (it happens)
you could have a drain, check amp draw on bettery with everything turned off
Thanks for the responses.
Had a garage check voltage, had 14v while running, 13 and decreasing till 12 something when turned off, so seems alternator is fine.
He had one of those light up screwdrivers and it lit up so somethings pulling current, but he couldnt measure the drain as never had the correct meter. I tried pulling a few fuses but nothing put the light out. I wouldve thought this would be (A) because the car pulls a little current anyway or (B) I pulled the wrong fuses. Guess I need a voltmeter to find that out.
Any other ideas guys?
