JBSRevo Technik
Results 1 to 28 of 28
    Quattro180's Avatar
    Oxfordshire
    96
    Post Thanks / Like
    HELP!! What is this noise?
    click on the picture below and listen to the strange noise coming from the air intake. I am sure that something is wrong with it? Any ideas????
    cheers
    2004, A4 Avant SE, 1.9tdi 130. Gunna do s line or s4 body upgrade
    WANTED - sport suspension, front s line or s4 bumper, door blades, 17" s line 5 spoke alloys, rear roof spoler
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    chicken flu ?
    Quattro180's Avatar
    Oxfordshire
    96
    Post Thanks / Like
    ha ha
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    955
    Post Thanks / Like
    mine does exactly the same, i havnt fully investigated it yet but suspect iether a split intercooler or the metal pipe that connects them at the bottom. sounds almost like intercooler pipework is pressurising and maybe a split is opening up and sucking in air when a ceertain pressure is reached.Anyone else ever heard this before?
    Quattro180's Avatar
    Oxfordshire
    96
    Post Thanks / Like
    Thing is, it's a pain in the arse to take apart and test!!!
    diffas's Avatar
    Lahti, Finland
    94
    Post Thanks / Like
    Sounds like compressor surge.
    Slow and smoking - A4 2.5TDi+ 204kw/570nm
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    955
    Post Thanks / Like
    Quote Originally Posted by diffas View Post
    whats compressor surge?
    Quattro180's Avatar
    Oxfordshire
    96
    Post Thanks / Like
    Good question !!!
    diffas's Avatar
    Lahti, Finland
    94
    Post Thanks / Like
    Surge generally refers to a condition where airflow moves backwards in the compressor, whether in an axial flow compressor (blade tip stalling) or a centrifugal compressor. (ie: turbocharger).
    Airflow moving in two directions during surging "crashes" inside the compressor and can stall the compressor, cause mechanical damage, or in a small surge disrupt the operation/speed of the compressor momentarily.
    Turbocharger - Wikipedia, the free encyclopedia
    Quattro180's Avatar
    Oxfordshire
    96
    Post Thanks / Like
    I am taking the car to a garage on Saturday, will report back findings
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    955
    Post Thanks / Like
    Please do i would get mine into a garage to had someone not tried to park a rangerover on it last week. its in the body shop at the mo. I would be very keen to hear the results as compressor surge sounds like code for you need a new turbo.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    955
    Post Thanks / Like
    any news on the sound?
    Zookeeper Champion
    Jun 2010
    196
    Post Thanks / Like
    has anyone had any look with finding out what this is as mine is doing the exact same thing and its raly annoying lol
    Quattro180's Avatar
    Oxfordshire
    96
    Post Thanks / Like
    I asked an Audi mechanic and he said that some of the cars make this noise and some don't!! I am still not convinced tho. I also got vag plugged in and cleared a mass air flow meter fault and the noise isn't so bad now. This fault was caused when I took the air flow pipes apart and started the engine. My mpg is around 33-35 mpg aswell which is about right.
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    i would have said its turbo related, it only happens when you come off the throttle so as has been suggested above i would suspect compressor surge.
    Im not sure how TDIs work but the petrol 1.8T have a valve between the turbo and the intake manifold which when you come off the throttle relieves the back pressure and stops compressor surge/stall. If turbo diesels work the same then it may be just a case of getting this valve checked.
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    May 2010
    cleveland
    295
    Post Thanks / Like
    could a crudded egr cause this
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    955
    Post Thanks / Like
    do diesels have a dump valve?
    Alex C's Avatar
    Lizard, Cornwall
    1,862
    Post Thanks / Like
    thats what i mean when i say i dont know how TDIs work, i dont know if they have a DV
    Alex S3 AMK
    TDIPOWARRR
    Jul 2010
    Scarborough
    613
    Post Thanks / Like
    No diesels dont have a dump valve.
    2003 Audi A4 Avant-tdi 130-Remapped, Allard EGR Pipe, Smooth airbox, HIDS, Flyeye kit, de-chrome grill, de-badged.
    Coming soon-18s or 19s
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    955
    Post Thanks / Like
    so if there is no dump valve what is there to stop compressor surge because i dont think these engines do this as normal. Am i right in thinking that a diesel doesnt suffer from this as there is no throttle flap like a petrol engine. There is as said above a flap inside the egr valve. Any diesel experts about?
    Zookeeper Champion
    Jun 2010
    196
    Post Thanks / Like
    no d.v ud think there was with that noise lol its realy anoyin mine never did ths when i first got my b6 butafter taking intake parts apart for cleaning ive had the very same noise ive cleaned egr so dont think its to do with it being clogged would love tknow where to begin to eliminate this even if it was trial and error. will it not log on vag com?
    May 2010
    cleveland
    295
    Post Thanks / Like
    leak in the intake????? as u just said started after you messed with that area?????
    Zookeeper Champion
    Jun 2010
    196
    Post Thanks / Like
    had car on vag com no fualt there to suggest anything also cheacked fo obious leaks but all looked ok after a good mess around though it can only be dcribed as when reved sems abit restrictive on thesuck of air in and once let off the peddel air seems to flw back to the air filter box and blow out there making that noise so def seems like restriction or blockage somewhere any more thoughts guys? or anyone elsewith this problem fixed it yet?
    Dec 2010
    Huddersfield
    30
    Post Thanks / Like
    Any updates on this as I have the same issue with my V6tdiQ.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    955
    Post Thanks / Like
    I believe i have stopped the noise now from happening it certainly doesnt do it now, i was having a hesitation when it came on boost and was trying to fix it, i fitted a blanking plate to the egr to remove it from the system to see if this was the cause of the boost issue and low and behold the noise has stopped as in the video and i no longer have the hesitation either, so my guess is that it is being caused by the egr valve possibly the flap inside it isnt closing fully so there is air getting through when it should be closed. I havnt taken it off all i have done is to fit a plate to the egr valve itself at the front of the car side of it, you will see when you look. A friend gave me a plate a while ago but you could make one out of a piece of flat steel or stainless, just remove the pipe that goes between the egr and the intake manifold and draw around it as a template, it wont cost anything to do really apart from an hour of your time.
    V6 Quatt's Avatar
    Feb 2008
    220
    Post Thanks / Like
    Noticed your post on this,
    could you post some pictures for all us 2.5 owners re a how to block EGR valve please.
    Thanks.
    Quote Originally Posted by swarcup View Post
    Torque the Torque
  28. #27
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    955
    Post Thanks / Like
    will do. here is a photo of the plate insitu, its the silver band you see inbetween the egr and the pipe. Im thinking i should remove the vacuum pipe from the top of it and block it as at the moment im sure it will still be operating but there will be no gasses passing through
    feel free anyone to comment.
  29. #28
    Dec 2011
    Post Thanks / Like
    Hi all... Would just like to share and confirm some info... The noise is defo something to do with the egr system... My 2004 v6 started making the same noise after blowing an intercooler... I had to drive the car home with it chucking serious amounts of black smoke:-( I removed the egr and gave it a real good clean, car felt better but still sneezing on gear change:-( this morning knocked up a quick blanking plate and BINGO!!! No noise at all, back to the fast, quiet! Car that I'm used to:-)) no warning lights and much happier knowing I'm not chucking dirty exhaust fumes back through my engine!!
