Badger5Volks Autos
Results 1 to 10 of 10
    philipjmarshall's Avatar
    Jun 2010
    swindon wilts uk
    91
    HELP....How to remove the birds muck safely from paint.
    Hi all
    Please can you advise me as to the best product to remove birds muck damage of the roof of my new car. IT WAS ONLY ON THERE FOR ABOUT AN HOUR. BUT IT LEFT A STAIN IN THE PAINT THE SIZE OF A 10P COIN.
    ive used my carnuba gold which has made it a lot better,but you can still see a haze where it was.
    i'm reluctant to use anything else with out advise.
    the amazing thing is i only fully waxed the car the day before.
    thanks
    Philip
    2010 Audi A3, Sportback 2.0 TDI 170 PS, S-line Black Edition,
    Exclusive Suzuka Gray, Exclusive Silver & Black Full Nappa Leather Heated Seats,
    Blue Tooth,Bose Symphony 6 CD - i Pod.
    Bi-Xenon Headlights / DRL Led, 18" Titanium alloy wheels.
    TOGWT's Avatar
    Jun 2010
    11
    Safe Removal
    To remove bird excrement without causing scratches; apply very little surface pressure, dusting with long strokes in one direction only, use a product that contains a surfactant; this will lessen surface scratching as they lift dust etc into the media used avoiding surface friction (use a solution of Optimum no-rinse (ONR) diluted 1:20 / distilled water in a fine mist spray bottle) and allow to remain in place as this will soften debris and allow it to be removed
    Use a long nap micro fibre towel to ensure the debris that is lifted from the paint surface remains in the nap and not on the towel surface thereby causing surface marring. Shake the towel occasionally to ensure any particles picked up will drop out rather than come to the surface while youre using it.
    Do not scrub hardened/dried excrement residue, birds use gravel to help digest their food so grit and sand are some of the major components, which can cause scratching as it is very abrasive and will scratch the paint surface. Once it softened (re-liquefied) it enables their removal with less likelihood of damage to the paint surface Do not use on a hot paint surface (soon after driving) as this will cause streaking
    ~ Providing unbiased advice that Professional and Enthusiast Detailers Trust ~
    Hunty's Avatar
    Cambridgeshire, UK
    171
    If you've washed it off and it's left a mark then the likelyhood is it's etched into the clearcoat buddy, a bit of elbow grease with a cleanser like SRP and it should remove the oxidisation, if that fails then you may need to use an abrasive polish, the menzerna range is a good one on VAG paint. What protection do you use on your paintwork? May be worth investing in some good quality wax or sealant, collinite 476s is a top protector, or finishkare 1000p. It will stop the Bird poo reacting so quickly with the paint.
    HTH,
    Neil
    3.2 V6 - Bring on the Burble!
    Jun 2010
    swindon wilts uk
    91
    thanks for your advise, its only slight. but i know its there.
    i will give the products you advised a go hunty, who do advise as suppliers??
    philip
    Hunty's Avatar
    Cambridgeshire, UK
    171
    Polished bliss do alot on here, I use cleanyourcar.co.uk the forum on there is excellent too with great guides on how to do most things detailing wise http://www.cleanyourcar.co.uk/forum/...31fb6310b1546a Hope you het it sorted buddy
    Neil
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    EASY!!! Lakes light cut pad and Menzerna 203s. Takes literally 5 mins!
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
    TOGWT's Avatar
    Jun 2010
    11
    Use the least abrasive product first-
    1. Use a chemical paint surface cleaner (Z-PC Fusion Dual Action Paint Cleaner)
    2. Try to dissolve the surface/etched deposits trying one or more of the following;
    a) Use a 2:1 or stronger solution of distilled water/distilled white vinegar (Acetic acid)
    b) Try a 2:1 solution of distilled water/Isopropyl Alcohol (adjust ratio as required)
    c) Or equal parts distilled water/distilled white vinegar/Isopropyl alcohol.
    3. Clean the effected surface with Klasse All-In-One or Zaino Z-PC Fusion Dual Action Paint Cleaner
    4. Use detailing clay to remove any `hard' surface granules
    5. Use a machine polish (Optimum Polish or Optimum Compound) and a cutting (LC White, Orange or Yellow) foam pad (speed # 4- 5.0) to level the surface
    6. For Ceramiclear or other hard clear coats substitute Menzerna for machine polish; PO 203 S - Power Finish
    7. Use the least aggressive polish/foam pad first, if this doesnt remove the problem step-up to a more aggressive polish / foam pad set-up
    8. Wet-sand with 2000, 2500 or 3000 grit finishing paper
    TOGWT's Avatar
    Jun 2010
    11
    Avian bomb First Kit- use a 1:20 Optimum No-Rinse (ONR) / distilled water solution in a fine mist spray bottle. The surfactants it contains encapsulate and trap bird and insect excrement, dry surface dust, or light dirt particles making them virtually non-abrasive and it can be used without causing scratches (check contents periodically as heat will evaporate the contents if stored in the cars trunk).. Apply with a long nap micro fibre towel using very little surface pressure, dusting with long strokes in one direction only. For stubborn stains, soak the micro fibre towel and allow it to remain i n place for a few minutes and then wipe away the debris.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Quote Originally Posted by phoenixv6quattro View Post
    Menzerna 203S + Lake Country Light Cut Hand Pad - Definitely the best starting point for an acid etching problem like this!
    tspar's Avatar
    Dec 2009
    24
    Kitchen roll soaked in hot water, place on bird poo, leave for 10 mins and then wipe off !!. Worked for me for years
    Silver '07 S3 - Practical, good looking and goes like stink !
    Previous mota's of note:
    Golf V6 4 Motion
    MK 4 .:R32
