AH FabricationsEM Tuning
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Cleaning detailing advice.
    Hi all.
    As its pretty good weather for once, im planning on cleaning my car.
    Tools are;
    Wash mit.
    Dodo lime Prime
    AG srp.
    dodo rainforest rub
    and some big drying towels.
    Can i use a drying towel for buffing? as im short of microfibres.
    And is it worth applying AG EGP after the dodo??
    cheers
    Callum
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,078
    SRP and Lime Prime are the same sort of step product. Only SRP has fillers. I would stick with LP personally as the fillers will just fall out over time and take your paint work back to it's marred self.
    And to your last point, no, other way around.
    Wash - clay (if you're doing it) - polish (SRP or Lime) - seal (EGP) - wax.
    Ideally get a buffing towel as you will undo the work you have done with the LP if your towel is not particularly good.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Ive decided against polish/ filling.
    So, washed, clayed (with homade lube eugh) and part way through waxing now.
    Ill hopefully get a DA next month before the good weather, so i can lose some swirl marks.
    Im in dire need of paint correction.
    JD09's Avatar
    Dec 2009
    3,078
    You need to polish after claying chap. The wax will have very little to bond to, especially if you still have clay lube residue present on the bodywork.
