Badger5AH Fabrications
Thread: what polish??
    gonna getcha
    Dec 2006
    somewhere where the the speed limit is over 150mph.
    72
    what polish??
    HEY YOU GUYS!! WHAT DECENT GOOD POLISH FOR MY NEW PRIDE AND JOY A4 AVANT T SPORT 190BHP. S LINE SPEC. BRILLIANT RED. I HAVE LOADS OF SWIRL MARKS AND WANT TO POLISH OUT WHAT ABOUT A POLISH WITH A MOP?? WHAT DIFFERENT POLISH DO YOU ALL USE? PEACE AND LOVE AND HAVE A GOOG WEEKEND.
    Hunty's Avatar
    Cambridgeshire, UK
    171
    Hey cominatcha.
    This is a massive question. And I have a little time on my hands so here we go!
    If you want to get rid of the swirls you will have to get a Daul action polisher (DA For short), the DAS6 from polishedbliss or cleanyourcar are great, I have this and its great! I have the menzerna pads but would recommend the sonus pads personally. http://www.cleanyourcar.co.uk/polish.../prod_520.html but this is the kit I got - http://www.cleanyourcar.co.uk/polish.../prod_522.html. They both have everything you'll need to remove the swirl marks. The DA is pretty safe, rotary polishers are a little chaeper but you need a bit of practice before having a go on your car (use scrap car panels or a partners/wife's car!!!) Menzerna polishes are brillian and what most recommend. I use these and get brilliant results, the only polish I will ever use. You remove swirls by taking down the clearcoat, so care must be taken when doing this to not go strike through the clearcoat. Start with the least abrasive polish and the lightest cutting pad, then work your way down to the finish you require, but audi paint is pretty hard and thick, so it shouldn't be too much of an issue.
    I understand that this is a pretty expensive kit, you can do it by hand, however to remove swirls it is extremely hard work and can take days if you want to do a proper job! But this is a great kit for polishing by hand http://www.cleanyourcar.co.uk/index....d&productId=29 .
    The other way to do it is to fill the scratches by using a filling polish, poorboys black hole or autoglym super resin polish. These can be applied by hand or DA. But it won't be permanent and it won't be as good a finish as removing the swirls permanently.
    Or you could hire a detailer to do the job professionally for you so all you need to do is aquire a decent washing method to keep swirls to a minimum, as this is when most swirling occurs. But where's the fun in that!!! (Just my opnion) Here are some decent guides.
    DA Polishing - http://www.detailingworld.co.uk/foru...apolishing.pdf
    Swirl removal - http://www.cleanyourcar.co.uk/forum/viewtopic.php?t=28
    Washing - http://www.cleanyourcar.co.uk/forum/viewtopic.php?t=27
    Then all you have to do is chose some Later stage products (LSP's). Would you like some advice on those as well?
    Sorry if its too much info,
    Neil
    gonna getcha
    Dec 2006
    72
    hey thanks for the information. any more information is a good thing cheers bud.... nice one
    Hunty's Avatar
    Cambridgeshire, UK
    171
    Once you've polished buddy, I'd suggest going for something like Clearkote Red Moose Glaze, just look at the results Jim got on the red RS4! http://www.audi-sport.net/vb/showthr...-Cabriolet-Red Its a great Glaze! Jim then used Dodo juice supernatural wax, which is a little pricey. Personally, if you want to go for a great look, victoria concours wax looks great on red and blacks especially http://www.cleanyourcar.co.uk/wax/vi.../prod_312.html but you'll have to re-apply every month or so, will look good though, if you want more durability, collinite is always a good one, 915 especially IMO http://www.cleanyourcar.co.uk/wax/co.../prod_281.html but ask someone like clark from polished bliss will be a little more experienced from that piont of view. But won't go wrong with either of those waxes!
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Err, the polishing guides on our website talk in detail about how to polish by hand and machine, and also how to select the right polish(es) for your paint type type (which will be hard). Grab a coffee and read these links for enlightenment...
    About the polishing process - http://www.polishedbliss.co.uk/acata...ishing-do.html
    How to choose the right polish - http://www.polishedbliss.co.uk/acata...uld-i-use.html
