AH FabricationsVolks Autos
Results 1 to 9 of 9
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Thumbs up Recommended products/routine for white and light metallic/pearlescent Audi's
    Many people find it difficult to achieve an excellent finish on solid white and light metallic/pearlescent colours, no matter how well they prepare their paint. This is because the lightness of tone precludes a high degree of reflectivity, and thus makes it hard to achieve a finish with any real clarity and depth. Furthermore, this lack of reflectivity can also limit how wet the paint looks, as fewer highlights are shown up in the finish. However, these problems can be largely overcome by choosing a synthetic sealant instead of a natural carnauba wax as the last step product. This is because sealant polymer chains tend to cross-link to form an exceptionally smooth, highly dense surface layer that reflects light far more efficiently than a microscopically rougher, less dense natural carnauba wax coating, and this can add a significant amount of wetness to the appearance of the paint, as more highlights are shown up in the finish. Moreover, the same smoothing and filling properties also minimise any scattering of light caused by micro-structures in the surface of the paint, meaning that reflections are afforded greater clarity and depth, and that metallic and pearlescent flakes receive more transmitted light and thus appear to stand out more from the base colour (a phenomenon commonly known as flake pop).
    Out of the various synthetic sealants we stock, we favour the Werkstat Acrylic Kit for optimal results on solid white and light metallic/pearlescent colours. This is because it delivers an incredible level of reflectivity characterised by amazing clarity and depth, and makes metallic and pearlescent flakes stand out from the base colour more than any other product we have used. Indeed, on some light metallic colours we have worked on, it has literally made the flake appear to explode out of the surface of the paint when viewed in direct sunlight. Further benefits afforded by the Werkstat Acrylic Kit include terrific ease of use, even in cold and damp conditions, and excellent durability, with a single application of the three component system typically lasting for around three months on a daily driver, although this can be extended almost indefinitely if regular quick detailing is undertaken. If your budget is too small to stretch to the Werkstat Acrylic Kit, there are two alternative options worth considering. The first is Blackfire Wet Diamond All Finish Paint Protection, which delivers an equally intense wet looking shine, albeit with a little less flake pop. The second is Poorboys EX-P Sealant, which delivers a sharp wet looking shine with good flake pop, and offers excellent value for money.
    Given the above, here is the optimal routine and products we recommend for use on white and light metallic/pearlescent colours (assuming all work is to be done by hand)...
    Wash (ideally every week, including wheels)
    Advanced Car Wash Kit - http://www.polishedbliss.co.uk/acata...-kit-wash.html (choosing the Werkstat shampoo)
    Decontaminate (once or twice a year, spring and autumn are the best times)
    Step 1 - Autosmart Tardis & Accessories (to remove tar spots, tree sap, etc) - http://www.polishedbliss.co.uk/acata...dis-clean.html
    Step 2 - Meguiars Quik Clay Kit (to remove industrial fallout, soot, etc) - http://www.polishedbliss.co.uk/acata...kit-clean.html
    Polish (after claying, thus done once or twice a year)
    To correct swirl marks and other light to moderate defects (fine scratches and oxidation) on your car, we recommend using Menzerna 203S in conjunction with Lake Country German CCS Light Cut Pads. Working small areas at a time using moderate pressure should enable you to correct a reasonable amount of the defects present in just 1-2 attempts per panel. You should be aware from the outset that although this method will yield very good results, it will require a reasonable amount of elbow grease! Of course, if your paint is in excellent condition with no visible sub-surface defects, you can skip this step and go straight to the addition of the protection (see below)...
    Menzerna 203S - http://www.polishedbliss.co.uk/acata...3s-polish.html
    Lake Country German CCS Light Cut Pads - http://www.polishedbliss.co.uk/acata...ds-polish.html
    Poorboys Super Thick & Plush Towels - http://www.polishedbliss.co.uk/acata...el-polish.html
    Protect (add fresh protection every 6-8 weeks for best results)
    Werkstat Acrylic Kit - http://www.polishedbliss.co.uk/acata...t-protect.html
    This excellent value for money kit includes everything you need to achieve the Werkstat acrylic finish on your car, and works best on lighter colours and metallic/pearlescent finishes. Werkstat Prime Acrylic is a light finishing polish that lays down a tough initial coat of acrylic protection whilst deep cleansing the paint; you should use it once every six months after claying/polishing. Werkstat Acrylic Jett Trigger is a pure spray sealant that should be used to add more gloss and protection every 6-8 weeks; the more layers you build up, the better the finish will get, in terms of both wetness and durability. Werkstat Acrylic Glos is a quick detailing spray and can be used to help boost gloss, lubricate when drying off after washing and loosen the residues of Werkstat Prime Acrylic and Werkstat Acrylic Jett Trigger should you find them hard to remove. Here are full instructions for each major six-monthly detail with the products...
    After washing and claying (and corrective polishing if required), start out by applying a basecoat of Werkstat Prime Acrylic using the white Meguiars Microfibre Applicator Pad. Once fully dry, buff off this residue carefully with the Poorboys Super Thick & Plush Towel, using a spritz of Werkstat Acrylic Glos to help loosen the residue if needs be. To complete the process, apply a coat of Werkstat Acrylic Jett Trigger by spraying directly onto each panel and buffing off immediately with the Poorboys Deluxe Mega Towels, again using a spritz of Werkstat Acrylic Glos to help loosen the residue if needs be. To maintain the finish, simply quick detail with Werkstat Acrylic Glos after each wash, and add a fresh coat of Werkstat Acrylic Jett Trigger every 6-8 weeks until the time comes to start over by claying again.
    Here are some pictures showing the finish the above products/routine gives on white and light metallic/pearlescent colours, in order to give you some idea in advance...
    thelomondaudigroup's Avatar
    Glasgow, United Kingdom, United Kingdom
    270
    Follow thelomondaudigroup On Twitter Add thelomondaudigroup on Facebook Visit thelomondaudigroup's Youtube Channel Visit thelomondaudigroup's Instagram Channel
    Hi mate, really interested in this post but seems the links are out of date? Could you maybe point me in the direction/update the links so I can have a look for myself?
    Chris
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    17th March 2010 - link updates
    Advanced Car Wash Kit - http://www.polishedbliss.co.uk/acata...-kit-cat1.html (choosing the Werkstat shampoo)
    Step 1 - Autosmart Tardis & Accessories (to remove tar spots, tree sap, etc) - http://www.polishedbliss.co.uk/acata...rdis-cat6.html
    Step 2 - Meguiars Quik Clay Kit (to remove industrial fallout, soot, etc) - http://www.polishedbliss.co.uk/acata...-kit-cat1.html
    Menzerna 203S - http://www.polishedbliss.co.uk/acata...203s-cat8.html
    Lake Country German CCS Light Cut Pads - http://www.polishedbliss.co.uk/acata...pad-cat24.html
    Poorboys Super Thick & Plush Towels - http://www.polishedbliss.co.uk/acata...wel-cat24.html
    Werkstat Acrylic Kit - http://www.polishedbliss.co.uk/acata...-kit-cat1.html
    wyliss's Avatar
    Aug 2004
    North West
    284
    Hi Rich
    You recommend Lake pads to do Audi's but looking at their spec it says not suitable for hard paint.
    Isnt Audi paint hard ?
    A4 B7 2.0T FSI S-LINE Akoya Silver, Xenon plus pack, RS 6's, MFSW, Dension, Auto dimming mirror, Light/Rain sensor, Bose, Isofix, Split folding seats, Rear side blinds, Rear window blind, Centre armrest, Auto boot Lid, Cargo parcel net/hooks,Loadliner & Votex Rear Diffuser. Tyres: presently running Vredenstein Sessanta's: SUPERB!
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    The above recommendations/links all point to the Lake Country hand pads for hand use, and in this sense they are perfect for hard Audi paint. The pads you are thinking of are the ones for use by machine, and in this sense Lake Country pads aren't as good as those made by Menzerna. So, by hand Lake Country hand pads are ideal for Audi paint, but by machine look to the Menzerna pads instead.
    Jun 2011
    59
    Hi Rich,
    Would the same effects as in your photos be achieved with akoya silver Audi's??? It would be great if it did.
    Hipotethically speaking if one would want to purchase all of the products that you mention would you offer some sort of discount???
    Jack
    Feb 2011
    42
    sweeeeet i was looking for a thread like this!
    Apr 2013
    We offer Advertising contact Admin to do it.
    Jun 2014
    Hi there, do you ship to New Zealand or know of any online retailers who ship to NZ. I have a 2012 Silver Audi A3 Sportback
